07 November 2026, 04:43:35
For the past 24 hours: 59 objects added, 97 objects edited, 22 objects removed.
Russian Federation > Ярославская область
06 January 2011, 02:44:55
18 January 2011, 11:24:00
надо бы скорость добавить)
21 January 2011, 09:46:10
Генаха, changed speed limit from 10 to 20.
Генаха, changed warning direction from 0 to 184.
21 January 2011, 09:46:52
01 June 2012, 06:22:49
неверные координаты. Тут лежекопа нет. Верные 39.96790768147582 57.6216217482849
01 June 2012, 06:36:59
леха150, changed object latitude from 39.968659 to 39.967961
леха150, changed object longitude from 57.624747 to 57.621622
леха150, changed warning direction from 184 to 190.
леха150, changed object notification distance from 500 to 200.
01 June 2012, 06:37:14
леха150, changed object latitude from 39.967961 to 39.967961
01 June 2012, 06:37:29
леха150, changed object latitude from 39.967961 to 39.967962
01 June 2012, 06:38:36
Поставил по координатам,только на дорогу.
24 June 2019, 20:07:35
yuryleb, changed object view angle from 15 to 30.
11 March 2025, 15:31:24
не актуально -1
11 March 2025, 15:31:26
не актуально -1
11 March 2025, 15:54:06
См выше -1
11 March 2025, 15:54:08
См выше -1
11 March 2025, 15:54:10
См выше -1
11 March 2025, 15:54:19
11 March 2025, 15:54:28
11 March 2025, 16:00:21
Добил -1
11 March 2025, 16:00:26
Добил -1
11 March 2025, 16:00:29
Добил -1
