05 November 2026, 07:13:59
For the past 24 hours: 73 objects added, 87 objects edited, 18 objects removed.
Обгон запрещен 3км
15 December 2019, 10:02:02
15 December 2019, 10:19:55
semaa1, changed object latitude from 103.749760 to 103.749948
semaa1, changed object longitude from 52.496582 to 52.496656
semaa1, changed object type from  Other danger Other danger to  Overtaking prohibited Overtaking prohibited.
semaa1, changed speed limit from 70 to 90.
semaa1, changed speed limit from 0 to 70.
semaa1, changed warning direction type from Two directions to In a certain direction.
semaa1, changed warning direction from 168 to 160.
semaa1, changed object view angle from 15 to 42.
semaa1, changed object description from 'Объект добавлен с помощью программы MapcamDroid (offline)' to 'Обгон запрещен'.
semaa1, confirmed object added via Mapcam.info program
15 December 2019, 12:46:19
15 December 2019, 14:19:31
Померил по дороге так и есть 1,5 км. Я на форуме писал чтобы можно было вторую точку ставить - конец запрета. Молчат.
15 December 2019, 15:56:55
Пока это в очереди на реализацию. Когда будет внедрено знает только админ.
27 January 2020, 15:08:00
Можешь поправить на 3км
27 January 2020, 14:59:45
semaa1, changed object latitude from 103.749948 to 103.749808
semaa1, changed object longitude from 52.496656 to 52.496649
semaa1, changed control area.
27 January 2020, 15:07:04
semaa1, changed object latitude from 103.749808 to 103.756042
semaa1, changed object longitude from 52.496649 to 52.489497
semaa1, changed warning direction from 160 to 133.
semaa1, changed object view angle from 42 to 30.
semaa1, changed object description from 'Обгон запрещен' to 'Обгон запрещен 3км'.
28 January 2020, 14:00:09
Elen, changed control area.
Elen, changed object description from 'Обгон запрещен 3км' to 'Обгон запрещен 2.5км'.
28 January 2020, 14:00:59
Померил линейкой от точки до точки.
28 January 2020, 14:07:43
Для этого она тут:). Посмотрел там где раньше стоял там второй знак. От знака до моста тоже сплошная.
28 January 2020, 14:25:23
Надо перетаскивать точку к сужению. Тогда будет 3 км. (На будущее; всё нужно проверять, чтобы не делать лишних телодвиженией ;))
28 January 2020, 14:43:31
Реально там сплошная, а чё я её сразу не дотощил :'(. Тогда 3 км. Кстати когда хвост в MCD заработает.
28 January 2020, 16:15:40
Это к Админу.. :)
28 January 2020, 14:40:49
semaa1, changed object latitude from 103.756041 to 103.760175
semaa1, changed object longitude from 52.489497 to 52.487080
28 January 2020, 16:16:14
Elen, changed object description from 'Обгон запрещен 2.5км' to 'Обгон запрещен 3км'.
04 February 2020, 12:36:19
