22 October 2026, 07:31:20
Russian Federation > Брянская область
07 January 2022, 09:07:14
20 February 2022, 15:27:31
DiK57, changed control area.
DiK57, changed warning direction from 93 to 97.
DiK57, changed object notification distance from 600 to 400.
20 February 2022, 15:28:59
20 February 2022, 15:29:22
DiK57, changed warning direction from 97 to 100.
05 June 2022, 18:35:06
janbrk, changed speed limit from 90 to 50.
janbrk, changed speed limit from 70 to 50.
07 June 2022, 14:54:19
Timon34, changed object description from 'СКАТ-С (тыл)' to 'КОРДОН-М 2 [138км 350м] (тыл)'.
07 June 2022, 14:55:08
Timon34, changed warning direction from 100 to 79.
Timon34, changed object view angle from 60 to 90.
19 May 2025, 14:14:36
, changed object latitude from 34.192874 to 34.192373
, changed object longitude from 53.279610 to 53.279662
, changed warning direction from 79 to 96.
19 May 2025, 16:50:29
Теперь комплекс э таким номером находится тут https://mapcam.info/speedcam/point.php?idm=h7SPeRaH2Wl
20 May 2025, 16:26:48
Демотнтирован. На удаление -1
20 May 2025, 16:26:51
20 May 2025, 16:26:53
20 May 2025, 16:32:39
20 May 2025, 18:21:06
выше -1
20 May 2025, 18:21:08
выше -1
20 May 2025, 18:21:10
выше -1
20 May 2025, 19:41:58
, changed object view angle from 90 to 20.
20 May 2025, 19:42:18
, changed object type from  Other danger Other danger to  Static speed camera Static speed camera.
20 May 2025, 19:42:27
20 May 2025, 19:42:35
20 May 2025, 19:42:59
, changed object description from 'КОРДОН-М 2 [138км 350м] (тыл)' to 'архив'.
20 May 2025, 19:46:55
