22 October 2026, 14:39:52
Кордон
18 December 2009, 19:10:10
Поменяйте тип камеры,а вместо двух камер на этом мосту можно оставить одну на два направления.
26 December 2009, 01:35:03
Mic, changed object type from  Twin camera Twin camera to  Static speed camera Static speed camera.
26 December 2009, 01:36:34
26 December 2009, 14:31:01
12 August 2010, 15:32:50
17 April 2011, 08:45:58
v3777, changed object notification distance from 500 to 300.
v3777, changed object view angle from 15 to 30.
18 May 2012, 18:30:34
Кто поможет указать или описать тип камеры? Поискать похожие можно здесь:Технические средства фиксации нарушений ПДД
29 August 2013, 19:44:39
benyamin, changed warning direction type from Two directions to In a certain direction.
benyamin, changed warning direction from 267 to 255.
benyamin, changed object notification distance from 300 to 500.
benyamin, changed object description from 'Агрономическая' to 'КРИС-С. Статическая камера, измеряющая скорость'.
29 August 2013, 19:45:38
Увеличил дальность оповещения, не достаточно. Разбиваю на два объекта
30 August 2013, 19:44:48
Johannes, changed object latitude from 49.216336 to 49.216315
Johannes, changed object longitude from 55.796517 to 55.796453
30 August 2013, 19:45:50
Перенес на свою полосу по OSM.
Желательно местным уточнить более точно по факту.
25 November 2013, 20:50:34
есть
+1
25 November 2013, 20:50:35
есть
10 September 2019, 11:29:11
10 September 2019, 11:29:22
10 September 2019, 11:29:35
10 September 2019, 14:27:38
Рейтинг завышен. -1
10 September 2019, 14:27:47
Рейтинг завышен. -1
10 September 2019, 14:28:09
Для мото неактуально. -1
10 September 2019, 14:38:50
Высоковат рейтинг шибко -1
10 September 2019, 14:38:53
10 September 2019, 15:23:35
Рейтинг завышен, до плюс 5 -1
10 September 2019, 15:23:40
10 September 2019, 15:23:45
14 January 2020, 22:02:57
14 January 2020, 22:04:08
15 January 2020, 01:28:41
15 January 2020, 01:30:00
Рейтинг завышен. Понизил до плюс 4. -1
15 January 2020, 01:30:03
15 January 2020, 03:22:06
18 April 2020, 09:16:08
18 April 2020, 11:17:31
Мото в ноль -1
05 October 2022, 16:27:47
УльяновскGSM, changed object description from 'КРИС-С. Статическая камера, измеряющая скорость' to 'Кордон'.
05 October 2022, 16:27:56
07 October 2022, 16:34:21
18 July 2023, 06:44:09
