23 October 2026, 14:55:53
For the past 24 hours: 25 objects added, 52 objects edited, 7 objects removed.
Азимут 4 [43км 953м]
21 June 2019, 17:31:43
21 June 2019, 17:32:37
serezhka, changed object latitude from 37.603603 to 37.603675
serezhka, changed object longitude from 55.370319 to 55.370271
21 June 2019, 17:52:14
21 June 2019, 18:44:24
21 June 2019, 18:46:48
Спасибо
21 June 2019, 18:45:32
ynbIPb, changed object latitude from 37.603675 to 37.603540
ynbIPb, changed object longitude from 55.370271 to 55.368487
21 June 2019, 18:50:33
Установил на дорогу
ynbIPb, changed object view angle from 15 to 20.
21 June 2019, 18:50:02
serezhka, changed object latitude from 37.603540 to 37.603153
serezhka, changed object longitude from 55.368487 to 55.368547
serezhka, changed warning direction from 6 to 8.
21 June 2019, 21:03:12
serezhka, changed object latitude from 37.603153 to 37.603245
serezhka, changed object longitude from 55.368547 to 55.368772
20 July 2019, 06:01:39
serezhka, changed speed limit from 70 to 90.
14 August 2019, 06:23:27
Ashkrmane, changed object description from 'СКАТ-С' to 'СКАТ-С [43км 953м]'.
14 August 2019, 06:23:37
14 August 2019, 06:23:38
14 August 2019, 06:23:48
14 August 2019, 06:23:50
20 September 2019, 07:14:02
25 September 2019, 12:20:13
Verr, changed speed limit from 90 to 110.
18 November 2019, 10:25:03
18 November 2019, 10:25:21
10 сентября было ещё 90
04 April 2020, 13:52:43
Парная камера, на среднюю скорость!
07 April 2020, 12:57:50
Это вторая камера по средней скорости. Первая 41 км 200 м.
07 April 2020, 13:03:26
Все уже сделано, пользуйтесь.
18 March 2021, 13:40:30
01 November 2021, 21:27:03
silandser, changed object notification distance from 500 to 900.
silandser, changed object view angle from 20 to 35.
02 August 2022, 09:55:11
serezhka, changed object type from  Static speed camera Static speed camera to  Traffic control complex Traffic control complex.
20 September 2022, 08:39:31
По моему этот скат снят, возможно временно.
20 September 2022, 08:39:49
20 September 2022, 09:03:00
это фото по направлению из Москвы?
20 September 2022, 09:09:51
Да
20 September 2022, 09:42:59
значит демонтирован и нужно понижать рейтинг
20 September 2022, 09:45:23
а его не перевернули на другую сторону?
20 September 2022, 09:53:05
Нет, с другой стороны такой же скат установлен. Думаю, что в тест надо поставить, его могут вернуть или заменить на другую камеру в ближайшее время.
20 September 2022, 10:00:40
поддерживаю
20 September 2022, 10:32:12
Verr, спасибо за внимательность и информирование.
20 September 2022, 10:29:36
Не переживайте, я все время здесь, сейчас все сделаю что не будет вас беспокоить.
20 September 2022, 10:29:53
serezhka, switched object to test mode
21 September 2022, 07:49:05
Камера на месте
21 September 2022, 07:50:01
serezhka, turned off test mode
02 February 2023, 09:51:55
02 February 2023, 09:52:24
Добавлен Азимут.
02 February 2023, 09:54:19
Verr, changed object description from 'СКАТ-С [43км 953м]' to 'СКАТ-С [43км 953м] + Азимут 4'.
02 February 2023, 13:18:35
kroxan, changed object description from 'СКАТ-С [43км 953м] + Азимут 4' to 'Азимут 4 + СКАТ-С [43км 953м]'.
kroxan, changed camera model.
02 February 2023, 13:19:36
02 February 2023, 13:19:50
СКАТ в перспективе на демонтаж..
02 February 2023, 13:21:33
Тогда убрать их все из названия если в паре новый Азимут висит
02 February 2023, 13:24:43
Интересно, а если превысить-с какой камеры штраф придет?
02 February 2023, 13:33:49
Думаю Азимут пока в тесте, ну а Скат уже плотно в рассылках. Да не, я о том что в перспективе старые снимать будут и все равно будем потом редактировать, так что повесили новую, предупреждение есть, им чтоб не возвращаться больше, сразу при появлении делать на новую.
02 February 2023, 14:23:07
Я о тех точках, где и Скат и Азимут по полгода уже висят. Есть такие места на Симферопольском, но вот фото штрафов пока видеть не довелось.
02 February 2023, 15:44:27
Я понял, так и написал, что Азимут в паре в тесте если рядом уже старая.))
02 February 2023, 15:44:58
serezhka, changed object description from 'Азимут 4 + СКАТ-С [43км 953м]' to 'Азимут 4 [43км 953м]'.
02 February 2023, 17:03:56
24 August 2024, 07:47:49
26 August 2024, 13:25:46
16 September 2024, 18:15:59
18 December 2024, 08:20:46
Модель: Азимут 4
Зав. номер: AZ500399
Свид. о поверке: С-ДЦГ/02-12-2024/392338812
Поверка действительна до 01.12.2026 г. включительно
Погрешность измерения:  /- 1.0 км/ч
18 December 2024, 08:21:24
05 September 2025, 08:50:53
10 September 2025, 04:38:18
10 September 2025, 04:39:27
Тот же Азимут стоит и работает
Модель: Азимут 4
