04 November 2026, 20:29:03
For the past 24 hours: 74 objects added, 99 objects edited, 17 objects removed.
Стрелка-Плюс (тыл)
21 April 2021, 18:53:29
21 April 2021, 19:05:57
Просьба добавить фото размер менее 1Мб
21 April 2021, 19:07:41
На обратном пути возможно смогу сфотографировать
22 April 2021, 17:27:15
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAkwAAAL2CAYAAACzNcnQAAAgAElEQVR4Aey9Z3hc93ntq3u/3JN7nOT6OHGKSyxZ3ZIoS y99w4SJIjee 9teh 0QR/0TgAEe6dEdcu2cpI4Jzm5J7HVZUmW48RJnOKT5z7rrncPhgTAATB7UATR8 F99syePTMbIGfjN td//U 8MADD8B07VPVZbjyMRaj9Jd/iqVZH/O8Pobu0hKtix9De/Gnqkp3gb9rlaU9/xEWozTnPsRCl5bvoTv7EeunKkqOf5/1no S/R/cU9qxD7CUS3PmPaitL LPo XPqZvPGn0PWjUVwO9Z/l0W63etOyufh6VZel53FqM0fB/Nhbul5fVxptLxeN35D3hu77Peg4G3pbRyfeA y7VPYLz0IeKdN/Bbj 7D6iNFqDv9p1h7tAT74p2w9byFhjN/DYP7FZTXXEKerhMZRU5k5NuQU hEdoEdyelGxCRWIiK2CKdiCnAiKh ZJXWwtV5F28W/Qv25v0XV2Xdh5vvrLnyIyoufsD6FhqW7wL9b/Hn03D 5ZJ9c/2W/3P4EpvMfo Haxyh1ncX 8HQcCIlEdlElGtt74Wrthb22DbVN/ahpGERIWAYS0zXoGriOM5deR0ffJRw4Gou4xHx0917E2fOvoKHpNE6eysDW7cdRVdeHzr6rMFrb0dA8ivJKF/IKbAgPz0bEqSwUFdqg1boQG5uHHdtDkZRYjHb3GVjNrYiMyEFcfDESksuRnmNCDLd7jibjyKls1LSOocjQjEN8nRKzG8a6AVTYO1HXdQlN/ddhax6Bobaf /tgbz6NQkM9nK3DyK6oQk5lFSwNfdDVdEJX3QltVQe03GqcHRBOGq/AgMl49ZNFASaBsqULTJ/w3NTV5wFY/oKTAFMgtRjAJO hFpi05wgr53nBn6HkmLvlBSaBIH LzzlHMPJZAku / Box97nH76lWRqelxpgWvyfQy1w v55BJg 7
22 April 2021, 17:27:46
22 April 2021, 17:30:10
s1v2s, changed object latitude from 37.842139 to 37.840951
s1v2s, changed object longitude from 55.703707 to 55.702731
22 April 2021, 17:30:51
s1v2s, changed warning direction from 33 to 214.
s1v2s, changed object notification distance from 197 to 224.
22 April 2021, 17:36:05
s1v2s, changed object latitude from 37.840951 to 37.840842
s1v2s, changed object longitude from 55.702731 to 55.702664
22 April 2021, 17:38:02
s1v2s, changed object latitude from 37.840842 to 37.840684
s1v2s, changed object longitude from 55.702664 to 55.702551
22 April 2021, 19:10:29
balabol.1974, changed warning direction from 214 to 212.
balabol.1974, changed object notification distance from 224 to 350.
balabol.1974, changed object description from 'Установили камеру. Смотрит на Лермонтовский проспект' to 'Стрелка-М-В'.
22 April 2021, 19:10:53
17 September 2021, 20:34:18
17 September 2021, 20:35:30
Камера работает в обоих направлениях
18 September 2021, 10:53:18
19 January 2022, 07:30:39
Перед камерой и до перекрестка с Лермонтовским проспектом установили ограничение 40
19 January 2022, 07:30:56
19 January 2022, 07:31:17
andrey_sp_rus, changed speed limit from 60 to 40.
29 April 2022, 08:27:02
актуально +1
29 April 2022, 08:29:18
balabol.1974, changed object description from 'Стрелка-М-В' to 'Стрелка-М-В (тыл)'.
20 June 2022, 09:43:34
20 November 2023, 19:53:09
20 November 2023, 19:53:29
20 November 2023, 19:53:32
20 November 2023, 19:53:34
06 June 2025, 14:31:09
, changed object description from 'Стрелка-М-В (тыл)' to 'МУЛЯЖ! Стрелка-М-В (рейтинг ноль)'.
06 June 2025, 14:31:22
нет в базе -1
06 June 2025, 14:31:25
нет в базе -1
06 June 2025, 14:31:27
нет в базе -1
06 June 2025, 14:49:17
муляж -1
06 June 2025, 14:49:20
муляж -1
06 June 2025, 14:49:25
муляж -1
06 June 2025, 14:49:44
04 August 2026, 20:03:08
, changed object latitude from 37.840684 to 37.840653
, changed object longitude from 55.702551 to 55.702562
, changed object description from 'МУЛЯЖ! Стрелка-М-В (рейтинг ноль)' to 'Стрелка-Плюс'.
04 August 2026, 20:03:17
замена +1
04 August 2026, 20:03:20
замена +1
05 August 2026, 08:56:13
, changed object latitude from 37.840654 to 37.840711
, changed object longitude from 55.702562 to 55.702555
, changed warning direction from 212 to 213.
, changed object notification distance from 300 to 250.
, changed object description from 'Стрелка-Плюс' to 'Стрелка-Плюс (тыл)'.
05 August 2026, 08:57:20
мото +1
