22 October 2026, 13:24:53
Лобачевский (тыл) [851км]
24 July 2017, 17:50:52
24 July 2017, 17:52:18
yohan, changed control area.
24 July 2017, 18:22:28
yohan, changed object description from 'Автодория' to 'Автодория [Каспий 847-849.5км]'.
03 November 2017, 11:48:43
03 November 2017, 15:07:30
Timon34, changed object description from 'Автодория [Каспий 847-849.5км]' to 'Автодория [Р-22 Каспий 848-850км]'.
03 November 2017, 15:07:42
штрафует, актуально +1
10 January 2018, 20:20:45
02 February 2018, 06:48:38
29 May 2018, 06:13:40
29 May 2018, 06:17:09
10 April 2019, 20:07:45
10 April 2019, 20:39:53
11 April 2019, 03:29:46
мото в 0 -1
02 March 2020, 13:41:53
02 March 2020, 13:42:16
см выше, демонтаж -1
02 March 2020, 13:42:17
02 March 2020, 14:07:07
Смотреть выше. рейитинг ноль -1
02 March 2020, 14:07:10
07 June 2020, 17:26:19
07 June 2020, 17:26:23
07 June 2020, 17:26:26
20 June 2020, 10:20:43
ксс демонтированы в январе 2020 года -1
19 July 2020, 16:57:32
Timon34, changed object latitude from 43.675725 to 43.682595
Timon34, changed object longitude from 49.598444 to 49.595044
Timon34, changed object type from  Twin camera Twin camera to   .
19 July 2020, 16:57:53
Timon34, changed object latitude from 43.682595 to 43.689998
Timon34, changed object longitude from 49.595045 to 49.592722
19 July 2020, 16:58:21
Timon34, changed object latitude from 43.689998 to 43.698152
Timon34, changed object longitude from 49.592722 to 49.591150
19 July 2020, 16:58:49
Timon34, changed object latitude from 43.698152 to 43.705727
Timon34, changed object longitude from 49.591150 to 49.589648
19 July 2020, 16:59:08
Timon34, changed object latitude from 43.705727 to 43.714632
Timon34, changed object longitude from 49.589648 to 49.587853
19 July 2020, 17:01:08
Timon34, changed object latitude from 43.714632 to 43.719000
Timon34, changed object longitude from 49.587853 to 49.587000
Timon34, changed warning direction from 318 to 288.
Timon34, changed object description from 'Автодория [Р-22 Каспий 848-850км]' to 'Астра-Трафик (тыл)'.
19 July 2020, 17:01:31
Актуализация, установили Астра-Трафик +1
19 July 2020, 17:01:34
19 July 2020, 17:01:37
19 July 2020, 17:01:52
Актуализация нужен плюс в легковые +1
19 July 2020, 17:02:00
19 July 2020, 17:02:03
19 July 2020, 17:02:53
См.выше.Актуально +1
06 September 2020, 11:28:39
Timon34, changed object description from 'Астра-Трафик (тыл)' to 'Астра-Трафик (тыл) [850км 270 м]'.
22 May 2021, 17:51:40
Timon34, changed object description from 'Астра-Трафик (тыл) [850км 270 м]' to 'Астра-Трафик (тыл) [851км]'.
01 November 2021, 10:26:29
И эту Астру демонтировали. Не понятно, вернут или нет. Штрафы с нее шли с завидным постоянством
01 November 2021, 16:22:23
13 April 2022, 15:55:54
Timon34, changed object latitude from 43.719000 to 43.720680
Timon34, changed object longitude from 49.587000 to 49.586624
Timon34, changed warning direction from 288 to 114.
Timon34, changed object description from 'Астра-Трафик (тыл) [851км]' to 'Лобачевский (тыл) [851км]'.
13 April 2022, 16:02:16
Timon34, changed object latitude from 43.720680 to 43.719930
Timon34, changed object longitude from 49.586624 to 49.586778
Timon34, changed warning direction from 114 to 288.
13 April 2022, 16:03:15
Замена на Лобачевского
14 April 2022, 18:38:16
yohan, turned off test mode
