22 October 2026, 08:13:56
Муляж! Вокорд
Russian Federation > Алтайский край
10 August 2012, 14:35:10
02 December 2012, 04:14:58
Стоит ферма в арке. Радардетекотор уверенно на нее реагирует. Знаю, что данные приходят в ГИБДД, лично писем пока не получал. +1
24 January 2015, 07:16:36
action_64, changed warning direction from 223 to 225.
action_64, changed object notification distance from 181 to 250.
action_64, changed object view angle from 17 to 25.
11 April 2015, 14:09:45
Реально есть такое. Иногда работает +1
11 April 2015, 14:29:01
action_64, changed object latitude from 83.755257 to 83.755096
action_64, changed object longitude from 53.343220 to 53.343114
action_64, changed warning direction from 225 to 226.
15 October 2015, 17:20:26
2maxic, changed object latitude from 83.755096 to 83.755112
2maxic, changed object longitude from 53.343114 to 53.343111
2maxic, changed warning direction from 226 to 228.
2maxic, changed object notification distance from 250 to 350.
2maxic, changed object view angle from 25 to 30.
2maxic, changed object description from 'Статическая камера, измеряющая скорость' to 'Вокорд'.
08 August 2018, 12:56:44
Может это АвтоУраган-ВСМ2?
19 February 2019, 18:44:26
20 February 2019, 04:04:46
Для мото в лоб неактуально. -1
01 June 2019, 07:31:20
01 June 2019, 07:32:30
uDAV163, changed speed limit from 60 to 40.
01 June 2019, 07:32:46
рейтинг завышен -1
01 June 2019, 07:32:50
рейтинг завышен -1
01 June 2019, 07:33:01
мото не актуален -1
01 June 2019, 07:33:17
12 March 2021, 13:09:22
Это совсем другая сторона улицы!
03 August 2020, 09:36:03
Там ограничение 60, а не 40. Ограничение 40 в обратную сторону.
12 March 2021, 13:08:30
terminator090909, changed speed limit from 40 to 60.
12 September 2021, 11:35:43
Комплекс частично демонтирован уже год как
12 September 2021, 11:35:54
12 September 2021, 11:36:10
12 September 2021, 11:36:13
25 September 2021, 14:46:23
До 0 -1
25 September 2021, 14:46:27
До 0 -1
25 September 2021, 14:46:49
2maxic, changed object description from 'Вокорд' to 'Муляж! Вокорд'.
