23 October 2026, 03:52:15
демонтаж
21 November 2020, 17:20:34
21 November 2020, 18:34:50
intruder197, changed speed limit from 80 to 100.
intruder197, changed speed limit from 0 to 100.
intruder197, changed warning direction type from Two directions to In a certain direction.
intruder197, changed warning direction from 313 to 133.
intruder197, changed object notification distance from 500 to 250.
intruder197, changed object description from 'Объект добавлен 2020-11-21 17:21:27 с помощью MapcamDroid' to 'Sova'.
intruder197, confirmed object added via Mapcam.info program
intruder197, changed camera model.
21 November 2020, 18:35:54
intruder197, changed object latitude from 37.779410 to 37.779396
intruder197, changed object longitude from 55.854908 to 55.855173
22 November 2020, 03:29:56
intruder197, switched object to test mode
22 November 2020, 11:41:43
22 November 2020, 16:46:26
intruder197, turned off test mode
23 November 2020, 16:08:50
intruder197, changed object description from 'Sova' to 'Стрелка-360-С'.
28 January 2021, 18:37:54
28 January 2021, 18:45:54
подтверждено штрафом +1
28 January 2021, 18:45:58
28 January 2021, 18:46:00
29 January 2021, 06:26:31
strogino799, changed object description from 'Стрелка-360-С' to 'Стрелка-360-С (фронт/тыл)'.
31 January 2021, 10:04:45
intruder197, changed object notification distance from 250 to 300.
01 February 2021, 13:06:23
17 March 2021, 08:47:24
17 March 2021, 08:47:43
17 March 2021, 08:50:32
17 March 2021, 08:50:33
19 March 2021, 12:07:56
08 June 2021, 04:05:04
intruder197, changed object description from 'Стрелка-360-С (фронт/тыл)' to 'Стрелка-360-С (фронт/тыл) [99км]'.
08 June 2021, 04:05:16
15 January 2022, 19:43:45
balabol.1974, changed object latitude from 37.779396 to 37.779264
balabol.1974, changed object longitude from 55.855173 to 55.855235
balabol.1974, changed object notification distance from 300 to 400.
balabol.1974, changed object description from 'Стрелка-360-С (фронт/тыл) [99км]' to 'Стрелка-360-С [99км]'.
15 January 2022, 19:50:14
balabol.1974, changed object notification distance from 400 to 500.
30 January 2022, 17:34:57
29 March 2022, 07:45:46
balabol.1974, changed object latitude from 37.779264 to 37.779641
balabol.1974, changed object longitude from 55.855235 to 55.855052
07 October 2022, 04:15:04
15 February 2024, 14:09:12
, changed object description from 'Стрелка-360-С [99км]' to 'демонтаж'.
15 February 2024, 14:09:24
ДЕМОНТАЖ -1
15 February 2024, 14:09:26
ДЕМОНТАЖ -1
15 February 2024, 14:09:27
ДЕМОНТАЖ -1
15 February 2024, 17:59:20
выше -1
15 February 2024, 17:59:23
выше -1
15 February 2024, 17:59:26
выше -1
15 February 2024, 18:00:17
