31 October 2026, 05:31:05
КОРДОН-М 4 [4км 145м]
02 March 2018, 10:47:35
02 March 2018, 10:48:15
Пока неопределенная камера, буду проезжать обязательно сфоткаю
02 March 2018, 10:50:05
Florian, changed object notification distance from 269 to 432.
14 March 2018, 17:07:29
Проезжал тут сегодня,стоит Кордон-М4
14 March 2018, 17:19:40
Ждём фото
14 March 2018, 17:07:53
dimas2233, changed object description from 'Неопределено' to 'Кордон-М4'.
14 March 2018, 17:12:36
прохоров, changed object notification distance from 432 to 500.
14 March 2018, 17:18:35
Primorets, changed object description from 'Кордон-М4' to 'КОРДОН-М 4'.
14 March 2018, 17:19:54
Добавил парную "в спину"
14 March 2018, 19:38:28
прохоров, changed object latitude from 38.717258 to 38.722860
прохоров, changed object longitude from 45.073854 to 45.071151
15 March 2018, 06:48:10
15 March 2018, 06:48:50
15 March 2018, 07:00:14
16 July 2018, 07:47:12
16 July 2018, 07:47:29
16 July 2018, 07:47:51
А вот и первенец! :)
07 August 2018, 15:58:59
КОРДОН
КОРДОН
08 August 2018, 05:16:23
Спасибо, Ваше фото из парной точки https://mapcam.info/speedcam/point.php?idx=838886 Просьба выложить его туда
08 August 2018, 05:16:49
Подтверждено +1
23 October 2018, 23:39:08
Для мото неактуально -1
24 October 2018, 02:33:02
23 March 2019, 02:26:51
setpiton, changed object description from 'КОРДОН-М 4' to 'КОРДОН-М 4 [136км 190м]'.
28 August 2019, 06:26:37
30 August 2019, 07:41:20
11 September 2019, 08:28:45
01 October 2019, 20:57:17
17 October 2019, 05:58:39
18 October 2019, 06:12:25
18 October 2019, 06:19:49
22 October 2019, 07:40:02
09 November 2019, 21:50:04
26 November 2019, 06:41:04
10 February 2020, 14:11:35
10 February 2020, 14:55:30
Многочисленные штрафы +1
10 February 2020, 14:55:34
20 February 2020, 19:22:51
avivolga, changed object latitude from 38.722860 to 38.722830
avivolga, changed object longitude from 45.071151 to 45.071128
30 April 2021, 06:36:31
14 May 2021, 05:37:01
06 July 2021, 06:43:40
DiK57, changed object description from 'КОРДОН-М 4 [136км 190м]' to 'КОРДОН-М 4 [4км 145м]'.
23 July 2021, 06:47:28
03 November 2021, 12:38:56
04 January 2022, 16:26:21
05 February 2022, 09:47:16
27 September 2022, 07:28:08
10 May 2025, 20:46:34
Недавно проезжал там.
В сторону Краснодара повесили знак 40, и разметку 40 сделали
12 May 2025, 08:43:43
только камеры нет там уже
12 May 2025, 10:11:52
Не исключено, что сняли временно, в базе ГИБДД точка по прежнему в строю
10 May 2025, 22:17:20
, changed speed limit from 60 to 40.
11 June 2025, 09:43:46
Камеры нет. Демонтирована
26 January 2026, 14:42:42
Если камеры нет то нужно фото загрузить и минус в рейтинг точки.  Или обратиться к автору точки, можно в лс продублировать.
Но без фото сейчас плохо. очень много ложных и неправильных корректировок может быть
11 June 2025, 15:36:14
Нет камер
26 January 2026, 15:46:33
см комент -1
26 January 2026, 15:46:37
см комент -1
27 January 2026, 13:33:27
27 January 2026, 13:33:31
30 July 2026, 23:06:14
30 July 2026, 23:06:18
30 July 2026, 23:06:20
30 July 2026, 23:06:47
29 August 2026, 12:50:25
Выше Удалил -1
29 August 2026, 12:50:38
Выше Удалил -1
29 August 2026, 12:50:51
