04 November 2026, 09:23:47
14 September 2017, 17:49:07
14 September 2017, 17:49:38
14 September 2017, 17:53:54
serezhka, changed object description from 'Статическая камера, измеряющая скорость' to 'АвтоУраган-ВСМ-2'.
14 September 2017, 18:10:22
serezhka, changed object latitude from 38.396621 to 38.396364
serezhka, changed object longitude from 54.873695 to 54.873843
serezhka, changed warning direction from 278 to 274.
serezhka, changed object notification distance from 453 to 400.
14 September 2017, 18:28:12
, changed object latitude from 38.396364 to 38.396353
, changed object longitude from 54.873843 to 54.873794
, changed warning direction from 274 to 275.
, changed object view angle from 15 to 30.
10 October 2017, 18:55:46
, changed object latitude from 38.396353 to 38.396611
, changed object longitude from 54.873794 to 54.873758
, changed warning direction from 275 to 100.
, changed object view angle from 30 to 20.
03 February 2018, 13:34:25
03 February 2018, 13:34:36
03 February 2018, 13:35:10
Поднимаю, подтверждено штрафом! +1
24 May 2018, 12:19:11
24 May 2018, 12:19:36
24 May 2018, 12:24:42
24 June 2018, 09:40:17
24 June 2018, 09:40:43
18 October 2018, 03:48:20
18 October 2018, 05:46:03
18 January 2019, 07:00:29
, changed object description from 'АвтоУраган-ВСМ-2' to 'АвтоУраган-ВСМ-2 (19км 550м)'.
26 May 2020, 16:13:05
17 October 2021, 17:59:24
intruder197, changed speed limit from 60 to 50.
17 October 2021, 17:59:48
Знак 50
07 December 2021, 06:49:42
27 June 2022, 11:08:22
29 October 2022, 14:15:21
02 June 2023, 18:23:14
14 July 2025, 17:57:10
29 September 2025, 05:39:24
перенос с к пешеходному переходу.
29 September 2025, 05:41:00
Двигать не даёт. создаем новый объект
29 September 2025, 05:41:12
перенос -1
29 September 2025, 05:41:14
перенос -1
29 September 2025, 05:41:15
перенос -1
20 October 2025, 08:52:02
20 October 2025, 08:52:05
20 October 2025, 10:08:38
Удалил, см выше -1
20 October 2025, 10:08:43
Удалил, см выше -1
20 October 2025, 10:08:56
20 October 2025, 16:18:05
, changed object description from 'АвтоУраган-ВСМ-2 (19км 550м)' to 'архив'.
