22 October 2026, 01:23:45
Опасный пешеходный переход
09 April 2014, 01:17:59
11 April 2014, 09:00:19
valur111, changed object latitude from 30.353657 to 30.353689
valur111, changed object longitude from 59.960342 to 59.960334
valur111, changed speed limit from 50 to 60.
valur111, changed warning direction from 337 to 339.
valur111, changed object notification distance from 500 to 150.
valur111, changed object description from 'Объект добавлен с помощью программы MapcamDroid (on-line)' to 'Опасный пешеходный переход'.
11 April 2014, 09:01:20
Нерегулируемый пешеходный переход через поток в шесть рядов, включая трамвайные рельсы.
20 February 2015, 12:44:26
valur111, changed object notification distance from 150 to 160.
01 January 2016, 16:53:04
valur111, changed object latitude from 30.353689 to 30.353638
valur111, changed object longitude from 59.960334 to 59.960372
valur111, changed object view angle from 20 to 25.
01 January 2016, 16:53:52
По GPS.
17 January 2017, 06:15:56
yuryleb, changed object view angle from 25 to 45.
08 February 2019, 18:55:07
yuryleb, changed speed limit from 60 to 40.
19 April 2022, 09:57:34
Часто стоит авто ГИБДД в первую половину дня по выходным, контроль пешеходного перехода.
09 March 2023, 08:15:04
Установлен светофор, на удаление.
09 March 2023, 08:15:26
09 March 2023, 08:15:35
09 March 2023, 08:15:52
02 March 2024, 12:28:12
См. выше -1
02 March 2024, 12:28:16
См. выше -1
02 March 2024, 12:28:20
См. выше -1
02 March 2024, 12:28:44
, changed object notification distance from 160 to 100.
