22 October 2026, 02:13:25
КОРДОН-М [486км 940м]
27 November 2018, 19:25:41
27 November 2018, 20:53:51
Развлекаемся? -1
27 November 2018, 20:53:54
Развлекаемся? -1
27 November 2018, 20:53:57
Развлекаемся? -1
28 November 2018, 06:52:05
Посмотрите мой профиль. Не шучу. Точка присутствует.
28 November 2018, 08:21:19
Timon34, changed object description from 'всем бобра. ну и намутили они тут с новыи интерфейсом. мультик в спину' to 'MultaRadar (в спину)'.
28 November 2018, 09:16:48
Просто шутим, оказывается +1
28 November 2018, 09:16:52
28 November 2018, 09:16:55
19 January 2019, 17:56:57
19 January 2019, 17:58:53
Никаких шуток. Фото выше
24 March 2019, 19:34:29
25 March 2019, 00:11:03
silandser, changed object description from 'MultaRadar (в спину)' to 'MultaRadar SD580 (в спину)'.
12 May 2019, 08:54:29
12 May 2019, 09:04:12
штраф +1
12 May 2019, 09:04:17
штраф +1
12 May 2019, 09:04:22
штраф +1
12 May 2019, 15:18:37
, changed object description from 'MultaRadar SD580 (в спину)' to 'MultaRadar SD580 (в спину) [486км 970м]'.
15 November 2019, 16:38:00
Фото +1
30 August 2020, 20:16:43
silandser, changed object type from   to  Static speed camera Static speed camera.
silandser, changed object notification distance from 600 to 800.
silandser, changed object description from 'MultaRadar SD580 (в спину) [486км 970м]' to 'ЛИДЕР-С [486км 970м]'.
30 August 2020, 20:16:50
30 August 2020, 20:16:58
09 November 2020, 14:37:28
23 March 2021, 18:34:43
silandser, changed object type from  Static speed camera Static speed camera to   .
silandser, changed object notification distance from 800 to 700.
silandser, changed object description from 'ЛИДЕР-С [486км 970м]' to 'ЛИДЕР-С [486км 970м] в спину'.
23 March 2021, 18:34:59
04 September 2021, 12:36:57
04 September 2021, 12:37:35
Ау, changed control area.
Ау, changed object description from 'ЛИДЕР-С [486км 970м] в спину' to 'ЛИДЕР-С [486км 910м] в спину'.
10 September 2021, 07:20:29
10 November 2021, 13:52:06
silandser, changed object latitude from 39.217973 to 39.218000
silandser, changed object longitude from 51.889412 to 51.890000
10 November 2021, 13:52:33
silandser, changed object notification distance from 700 to 800.
10 November 2021, 13:52:42
14 November 2022, 07:06:19
13 February 2023, 07:32:26
silandser, changed object latitude from 39.218000 to 39.217939
silandser, changed object longitude from 51.890000 to 51.889413
silandser, changed warning direction from 183 to 182.
silandser, changed control direction from In the back to Counter direction.
13 February 2023, 07:32:35
silandser, changed object description from 'ЛИДЕР-С [486км 910м] в спину' to 'ЛИДЕР-С [486км 910м]'.
17 August 2023, 20:54:13
17 August 2023, 20:55:11
Ау, changed object description from 'ЛИДЕР-С [486км 910м]' to 'КОРДОН-М [486км 940м]'.
04 December 2023, 16:12:00
10 May 2024, 13:04:36
10 May 2024, 13:05:20
Полный демонтаж. На удаление -1
10 May 2024, 13:05:23
10 May 2024, 13:05:25
10 May 2024, 13:05:50
, changed warning direction from 182 to 90.
, changed object notification distance from 800 to 100.
10 May 2024, 13:24:09
Выше -1
10 May 2024, 13:24:17
Выше -1
10 May 2024, 13:24:21
Выше -1
10 May 2024, 13:48:43
Выше -1
10 May 2024, 13:48:55
Выше -1
10 May 2024, 13:49:10
Выше. Удалил -1
10 May 2024, 14:03:22
