21 November 2026, 01:59:59
Знак ограничения скорости
10 May 2013, 16:19:18
10 May 2013, 19:57:46
valur111, changed speed limit from 60 to 40.
valur111, changed warning direction from 65 to 62.
valur111, changed object description from 'Объект добавлен с помощью программы MapcamDroid (on-line)' to 'Ограничение скорости 40 км/ч'.
11 May 2013, 10:07:51
Аналогично: http://mapcam.info/speedcam/point.php?idx=290383
Дубль? Удалить?
10 July 2013, 02:36:40
valur111, changed object notification distance from 500 to 400.
15 October 2013, 22:00:34
valur111, changed warning direction from 62 to 64.
01 June 2014, 22:04:22
valur111, changed object latitude from 30.046329 to 30.046347
valur111, changed object longitude from 60.714487 to 60.714510
valur111, changed warning direction from 64 to 63.
valur111, changed object notification distance from 400 to 350.
08 July 2014, 13:59:34
valur111, changed object latitude from 30.046347 to 30.046261
valur111, changed object longitude from 60.714510 to 60.714486
valur111, changed object notification distance from 350 to 300.
08 July 2014, 13:59:35
valur111, changed object description from 'Ограничение скорости 40 км/ч' to 'Знак ограничения скорости'.
08 July 2014, 14:03:06
По GPS.
26 September 2014, 12:05:10
valur111, changed object latitude from 30.046261 to 30.046497
valur111, changed object longitude from 60.714486 to 60.714560
23 May 2016, 19:17:10
valur111, changed object notification distance from 300 to 250.
26 September 2019, 14:53:03
убрали -1
26 September 2019, 14:53:07
убрали -1
26 September 2019, 14:53:09
убрали -1
26 September 2019, 14:55:13
26 September 2019, 14:55:23
26 September 2019, 14:55:31
25 October 2019, 19:50:45
Знак ограничения на месте. +1
25 October 2019, 19:50:50
25 October 2019, 19:52:04
25 October 2019, 19:52:43
Нужен плюс, 25.10.19 знак на месте.
26 October 2019, 20:21:37
01 December 2019, 16:06:24
См.выше +1
01 December 2019, 16:06:28
См.выше +1
01 December 2019, 16:06:32
См.выше +1
25 October 2020, 19:26:02
valur111, changed warning direction from 63 to 65.
valur111, changed object view angle from 20 to 25.
25 October 2020, 19:28:47
valur111, changed object latitude from 30.046497 to 30.046429
valur111, changed object longitude from 60.714560 to 60.714546
