22 October 2026, 02:13:27
Фактор
13 September 2021, 15:57:11
13 September 2021, 16:11:34
fantompg, changed speed limit from 0 to 90.
fantompg, changed speed limit from 0 to 70.
fantompg, changed warning direction from 180 to 202.
fantompg, changed object notification distance from 500 to 300.
fantompg, changed object view angle from 15 to 20.
fantompg, changed object description from 'Объект добавлен 2021-09-13 18:58:06 с помощью MapcamDroid' to 'Vocord Cyclops'.
fantompg, confirmed object added via Mapcam.info program
13 September 2021, 16:11:41
13 September 2021, 16:12:06
fantompg, changed object latitude from 34.265627 to 34.265987
fantompg, changed object longitude from 56.219979 to 56.219987
13 September 2021, 16:51:45
20 September 2021, 19:31:58
10 January 2022, 12:46:11
Замена на КРИС-С (Муляж)
10 January 2022, 12:46:50
fantompg, changed object description from 'Vocord Cyclops' to 'Муляж КРИС-С (рейтинг ноль)'.
11 May 2022, 08:51:34
11 May 2022, 08:52:14
Рейтинг НОЛЬ!!!
13 June 2023, 21:29:48
Камера повернута так, что может контролировать только одно направление, в спину.
29 June 2023, 08:15:51
Да, но при движении от М-9 водители видят этот муляж? Видят. Висит посередине дороги? Да. Значит им предупреждение о муляже необходимо.
13 June 2023, 21:30:26
Встречное направление не контролирует -1
13 June 2023, 21:30:28
13 June 2023, 21:30:30
14 June 2023, 04:52:57
14 June 2023, 04:53:24
11 December 2023, 09:33:17
fantompg, changed object description from 'Муляж КРИС-С (рейтинг ноль)' to 'Фактор'.
11 December 2023, 09:39:22
Замена муляжа на Фактор.
11 December 2023, 09:40:17
11 December 2023, 09:40:20
11 December 2023, 09:40:23
