23 October 2026, 01:46:22
Автодория [151-152км]
24 May 2015, 11:47:15
24 May 2015, 12:19:39
silandser, changed warning direction from 327 to 318.
silandser, changed object notification distance from 100 to 300.
silandser, changed object view angle from 13 to 15.
24 May 2015, 12:21:08
Как ставили точку? По GPS или "на глазок"?
Если не по координатам, то точки ставим по карте OSM при максимальном увеличении карты
13 September 2015, 11:07:53
uDAV163, changed object latitude from 47.835546 to 47.834535
uDAV163, changed object longitude from 54.615353 to 54.616122
13 September 2015, 11:14:18
13 September 2015, 11:15:02
Уточнил по координатам из постановления
12 July 2018, 12:20:31
22 August 2018, 13:00:13
SevSmith, changed control area.
SevSmith, changed camera model.
06 October 2018, 19:01:51
06 October 2018, 19:02:22
06 October 2018, 19:02:25
06 October 2018, 19:02:33
Мото. -1
18 March 2019, 19:48:02
УльяновскGSM, changed object description from 'Автодория' to 'Автодория [151-152км]'.
18 March 2019, 19:50:19
30 July 2021, 18:21:03
30 July 2021, 18:23:14
финишную камеру развернули
02 September 2021, 07:19:01
02 September 2021, 07:19:42
опять повернули
17 May 2022, 15:56:12
22 September 2024, 15:00:31
Камеры сняты.Ремонт дороги. -1
22 September 2024, 15:00:36
22 September 2024, 15:00:45
22 September 2024, 20:04:11
22 September 2024, 20:04:14
06 January 2025, 18:44:49
Отсутствует -1
06 January 2025, 18:44:52
Отсутствует -1
