22 October 2026, 08:13:13
Вокорд Трафик [108км 392м]
06 June 2020, 11:29:03
06 June 2020, 11:30:25
По просьбе. Фото здесь
06 June 2020, 11:53:53
21 July 2020, 06:17:25
На участке изменился  скоростной режим. Фото сделано за 300м до камеры.
21 July 2020, 06:17:35
21 July 2020, 15:31:05
Elen, changed speed limit from 90 to 70.
24 August 2020, 12:11:05
BeTaJIb, changed object type from  Static speed camera Static speed camera to   .
26 August 2020, 15:53:31
Спасибо! Мото плюс нужен.
BeTaJIb, changed object description from 'Статическая камера, измеряющая скорость' to 'Вокорд Трафик [в спину]'.
26 August 2020, 15:51:54
Elen, changed control area.
Elen, changed object description from 'Вокорд Трафик [в спину]' to 'Вокорд Трафик (в спину)'.
26 August 2020, 16:24:38
13 December 2020, 05:52:20
13 December 2020, 05:54:16
vaz2015, changed object type from   to  Static speed camera Static speed camera.
vaz2015, changed object description from 'Вокорд Трафик (в спину)' to 'Вокорд Трафик (в спину) [108км 350м]'.
13 December 2020, 05:58:20
vaz2015, changed object notification distance from 500 to 300.
vaz2015, changed object description from 'Вокорд Трафик (в спину) [108км 350м]' to 'Вокорд Трафик [108км 350м]'.
13 December 2020, 05:58:55
Скан штрафа выше +1
13 December 2020, 05:58:59
Скан штрафа выше +1
13 December 2020, 05:59:13
Не опасно мото -1
15 May 2021, 20:05:44
15 May 2021, 20:05:58
16 May 2021, 13:12:21
Elen, changed object notification distance from 300 to 400.
11 February 2025, 15:19:46
, changed object latitude from 36.622683 to 36.622781
, changed object longitude from 55.065105 to 55.065175
11 February 2025, 15:19:58
12 February 2025, 10:52:51
12 February 2025, 10:53:11
, changed object description from 'Вокорд Трафик [108км 350м]' to 'Вокорд Трафик [108км 392м]'.
04 October 2025, 15:33:55
Комплекс демонтирован -1
04 October 2025, 15:33:58
04 October 2025, 15:33:59
04 October 2025, 16:02:34
Отсутствует -1
04 October 2025, 16:02:36
Отсутствует -1
04 October 2025, 17:03:51
см выше, удалил -1
04 October 2025, 17:03:53
см выше, удалил -1
04 October 2025, 17:03:55
см выше, удалил -1
04 October 2025, 17:04:01
10 November 2025, 18:12:14
много +1
