17 November 2026, 23:44:20
For the past 24 hours: 93 objects added, 89 objects edited, 13 objects removed.
ОСКОН (29км 550м)
13 December 2017, 07:15:35
13 December 2017, 07:15:54
13 December 2017, 07:16:04
13 December 2017, 07:37:48
Спасибо. +
13 December 2017, 07:17:45
В выходные и в пятницу стоит стабильно, в другие дни я здесь не езжу поэтому не знаю про будни. Если кто видел в рабочие дни подтвердите пожалуйста.
13 December 2017, 07:20:50
iceberg333, changed object latitude from 37.231422 to 37.232451
iceberg333, changed object longitude from 55.839997 to 55.839989
13 December 2017, 07:21:24
iceberg333, changed object latitude from 37.232451 to 37.232430
iceberg333, changed object longitude from 55.839989 to 55.839904
13 December 2017, 07:33:43
feudor10, changed warning direction from 99 to 96.
feudor10, changed object notification distance from 450 to 500.
feudor10, changed object description from 'Передвижной комплекс видеофиксации превышения скорости' to 'ОСКОН'.
13 December 2017, 07:36:45
17 December 2017, 03:11:31
Вторые выходные его там вижу
+1
17 December 2017, 03:13:18
Оскон
Оскон
17 December 2017, 03:14:34
Кстати, он может спокойно сечь и встречку
26 January 2018, 10:29:12
Комплекс в работе и "говорит", что разрешенная скорость 60 км/ч на данном участке дороги.
26 January 2018, 10:30:55
26 January 2018, 10:31:32
26 January 2018, 11:54:30
Спасибо, плюс к карме.
26 January 2018, 10:34:27
Практически каждый день проезжаю там утром и вечером в будни - комплекса не бывает. А в выходные - частенько там стоит.
26 January 2018, 10:34:29
09 April 2018, 08:54:22
09 April 2018, 08:54:33
09 April 2018, 08:55:55
fantompg, changed object latitude from 37.232430 to 37.232408
fantompg, changed object longitude from 55.839904 to 55.839847
fantompg, changed speed limit from 50 to 60.
fantompg, changed warning direction type from In a certain direction to Two directions.
fantompg, changed object view angle from 15 to 25.
10 April 2018, 09:14:10
19 September 2018, 14:29:42
стоит каждый день!
21 September 2018, 16:49:15
16 January 2019, 20:33:13
, changed object description from 'ОСКОН' to 'ОСКОН (29км 550м)'.
16 April 2019, 20:39:58
irmos, changed speed limit from 60 to 50.
16 April 2019, 20:41:17
Судя по знакам, тут ограничение 50. Штрафы год не выкладывались. Предлагаю, если будет свежий штраф, где разрешенная скорость указана 60, вернуть обратно, а пока настроить точку согласно знакам
09 June 2019, 16:56:33
Коллеги, который раз здесь проезжаю. Никакого фургона, треноги не стоит. Думаю, скоро можно убирать отметку.
06 November 2019, 11:18:01
Уже несколько месяцев не стоит фургончик, не в будни ни в выходные. -1
06 November 2019, 11:18:05
06 November 2019, 11:18:08
06 November 2019, 11:33:32
Похоже надо точку удалять. Но как не знаю. Подскажите.
12 December 2019, 19:29:41
Товарищи с рейтингом, удалите объект пожалуйста! Уже писал ранее и не только я. Давно уже ничего не стоит в оба конца. Ни фургона, ни треног.
13 December 2019, 05:47:02
Я не знаю как удалить. Знающие - подскажите или сами удалите.
21 February 2020, 13:13:07
На карте кликаем по точке, появится окно в котором увидите Удалить объект
21 February 2020, 13:47:48
Спасибо, удалил.
21 January 2020, 04:57:50
Давно перестал стоять. Удалите точку
21 January 2020, 04:58:28
Оскон перестал стоять -1
22 January 2020, 10:38:06
см. выше -1
22 January 2020, 10:38:10
см. выше -1
22 January 2020, 10:38:13
см. выше -1
21 February 2020, 11:43:37
21 February 2020, 11:43:40
18 April 2020, 20:50:19
Полгода уже камеры не было видно на этом отрезке дороги.
28 April 2020, 05:24:33
Камера давно отмечена как неработающая.
