23 October 2026, 17:04:02
Автодория 3.5 [32км 054м]
Russian Federation > Республика Калмыкия
01 April 2020, 08:25:05
01 April 2020, 08:25:28
РЃ-РњРѕРЃ, changed speed limit from 0 to 90.
РЃ-РњРѕРЃ, changed object description from 'Объект добавлен 2020-03-30 14:59:20 с помощью MapcamDroid' to 'Статическая камера, измеряющая скорость'.
РЃ-РњРѕРЃ, confirmed object added via Mapcam.info program
01 April 2020, 08:25:47
Возможно это муляж! Просквозил под ней с явным превышением, но пока штраф не пришел. Камера очень похожа на "автодорию" висит по направлению "Из Москвы". Есть все атрибуты камеры, ящик, провода, антена GSM
01 April 2020, 11:33:00
Elen, changed speed limit from 90 to 70.
01 April 2020, 11:33:34
Elen, changed object view angle from 15 to 30.
11 May 2023, 19:10:49
Survey_19, changed object latitude from 45.525741 to 45.523550
Survey_19, changed object longitude from 45.905212 to 45.907550
Survey_19, changed warning direction type from Two directions to In a certain direction.
Survey_19, changed warning direction from 144 to 143.
Survey_19, changed object notification distance from 500 to 700.
Survey_19, changed object description from 'Статическая камера, измеряющая скорость' to 'Автодория 3.5 [32км 054м]'.
Survey_19, changed camera model.
12 May 2023, 05:45:41
21 July 2025, 20:24:37
21 July 2025, 20:25:05
21 July 2025, 20:25:08
21 July 2025, 20:25:35
