22 October 2026, 02:12:47
КОРДОН М2 [486км 940м]
27 November 2018, 19:27:28
02 December 2018, 10:35:19
19 January 2019, 17:57:51
19 January 2019, 17:58:11
Вид со стороны Воронежа
25 March 2019, 00:10:54
silandser, changed object description from 'мультик' to 'MultaRadar SD580 (в спину)'.
19 June 2019, 06:15:23
19 June 2019, 06:18:55
, changed object latitude from 39.217651 to 39.217702
, changed object longitude from 51.889491 to 51.889817
, changed object description from 'MultaRadar SD580 (в спину)' to 'MultaRadar SD580 (в спину)[486км 940м]'.
19 June 2019, 06:19:13
Есть штраф. +1
19 June 2019, 06:19:17
Есть штраф. +1
19 June 2019, 06:19:21
Есть штраф. +1
23 November 2019, 10:07:20
Ограничение 70 знак повесили
14 December 2019, 15:36:46
IbnSergey, changed control area.
IbnSergey, changed speed limit from 90 to 70.
09 May 2020, 15:42:52
silandser, changed speed limit from 70 to 90.
09 May 2020, 15:45:15
Ограничение скрости 70 км/ч уже нет.
09 May 2020, 15:43:02
30 August 2020, 20:18:00
silandser, changed object type from   to  Static speed camera Static speed camera.
silandser, changed object notification distance from 600 to 800.
silandser, changed object description from 'MultaRadar SD580 (в спину)[486км 940м]' to 'ЛИДЕР-С [486км 940м]'.
27 October 2020, 17:37:25
23 March 2021, 18:35:39
silandser, changed object type from  Static speed camera Static speed camera to   .
silandser, changed object notification distance from 800 to 700.
silandser, changed object description from 'ЛИДЕР-С [486км 940м]' to 'ЛИДЕР-С [486км 940м] в спину'.
04 August 2021, 20:52:17
Поймали коллегу на мотике в спину +1
02 September 2021, 20:09:22
10 November 2021, 13:54:55
silandser, changed object latitude from 39.217702 to 39.217669
silandser, changed object longitude from 51.889817 to 51.889616
silandser, changed object notification distance from 700 to 800.
18 November 2021, 19:08:49
21 January 2022, 07:04:54
17 February 2022, 13:34:12
29 April 2022, 13:24:42
01 June 2022, 08:01:57
27 June 2022, 18:29:48
26 September 2022, 08:12:47
14 October 2022, 08:55:07
04 November 2022, 07:40:36
21 November 2022, 13:25:58
01 December 2022, 06:28:56
02 February 2023, 09:07:39
silandser, changed control direction from In the back to Counter direction.
silandser, changed object description from 'ЛИДЕР-С [486км 940м] в спину' to 'КОРДОН М2 [486км 940м]'.
13 February 2023, 07:33:59
silandser, changed object latitude from 39.217669 to 39.217717
silandser, changed object longitude from 51.889616 to 51.890027
10 May 2024, 13:06:37
, changed warning direction from 3 to 270.
, changed object notification distance from 800 to 100.
10 May 2024, 13:06:46
Полный демонтаж. На удаление -1
10 May 2024, 13:06:49
10 May 2024, 13:06:52
10 May 2024, 13:23:44
Выше -1
10 May 2024, 13:23:48
Выше -1
10 May 2024, 13:23:51
Выше -1
10 May 2024, 13:47:12
См.выше. Удалил -1
10 May 2024, 13:47:25
См.выше. -1
10 May 2024, 13:47:35
См.выше. Удалил -1
