22 October 2026, 08:13:17
Арена в антивандальном ящике (177км + 272м)
Russian Federation > Алтайский край
14 April 2017, 04:33:58
14 April 2017, 04:34:40
siblord, changed object latitude from 83.730008 to 83.730738
siblord, changed object longitude from 53.641066 to 53.640506
siblord, changed warning direction from 160 to 157.
siblord, changed object notification distance from 500 to 516.
14 April 2017, 04:35:23
Напротив заправки слева антивандальный ящик
14 April 2017, 04:40:14
14 April 2017, 08:34:16
silandser, changed object latitude from 83.730738 to 83.730469
silandser, changed object longitude from 53.640506 to 53.640487
14 April 2017, 08:34:43
Поставил на дорогу по OSM
silandser, changed object notification distance from 516 to 550.
10 December 2017, 14:31:00
10 December 2017, 14:31:22
В ящике живет Арена!
10 December 2017, 16:06:37
10 December 2017, 16:51:41
штрафует +1
30 December 2017, 22:45:30
30 December 2017, 22:46:25
прохоров, changed object description from 'Антивандальный ящик под камеру' to 'Арена в антивандальном ящике'.
30 December 2017, 22:46:56
прохоров, changed object description from 'Арена в антивандальном ящике' to 'Арена в антивандальном ящике (177км + 272м)'.
30 December 2017, 22:47:11
14 October 2018, 23:15:07
14 October 2018, 23:18:10
15 October 2018, 02:34:13
Для мото неактуально. -1
15 October 2018, 02:43:17
15 October 2018, 02:52:54
26 March 2020, 10:47:55
semaa1, changed object type from  Static speed camera Static speed camera to  Integrated camera Integrated camera.
26 August 2021, 07:00:16
Бокс убран в связи с реконструкцией дороги
26 August 2021, 07:00:33
26 August 2021, 07:01:00
см. выше -1
26 August 2021, 07:01:03
см. выше -1
26 August 2021, 13:00:31
См. выше. -1
26 August 2021, 13:00:35
См. выше. -1
26 August 2021, 17:16:24
В ноль ?
27 August 2021, 02:44:46
Думаю да
25 September 2021, 14:38:06
До 0 -1
25 September 2021, 14:38:09
До 0 -1
15 August 2022, 03:19:35
Yoburger, changed speed limit from 70 to 90.
