22 October 2026, 03:52:35
КОРДОН-М 2
11 December 2013, 04:51:47
11 December 2013, 17:25:39
тат, changed object latitude from 32.969481 to 32.969476
тат, changed object longitude from 69.001085 to 69.001066
тат, changed speed limit from 80 to 70.
тат, changed warning direction from 331 to 330.
тат, changed object description from 'Объект добавлен с помощью программы MapcamDroid (on-line)' to 'Ограничения скорости 70 км/ч'.
тат, confirmed object added via Mapcam.info program
18 February 2015, 19:20:06
sademid51, changed object notification distance from 500 to 300.
sademid51, changed object description from 'Ограничения скорости 70 км/ч' to 'Ограничения скорости 70'.
16 November 2023, 18:17:03
sademid51, changed object latitude from 32.969476 to 32.972094
sademid51, changed object longitude from 69.001066 to 68.999292
sademid51, changed object type from  Speed limit sign Speed limit sign to  Integrated camera Integrated camera.
sademid51, changed warning direction from 330 to 331.
sademid51, changed object notification distance from 300 to 500.
sademid51, changed object view angle from 15 to 25.
sademid51, changed object description from 'Ограничения скорости 70' to 'Ящик под камеру'.
sademid51, changed camera model.
24 February 2024, 20:12:13
, changed object type from  Integrated camera Integrated camera to  Static speed camera Static speed camera.
, changed object description from 'Ящик под камеру' to 'КОРДОН-М 2'.
18 March 2024, 12:43:18
, changed warning direction from 331 to 146.
, changed object view angle from 25 to 55.
23 September 2024, 18:33:17
23 September 2024, 18:33:19
23 September 2024, 18:33:21
17 October 2024, 16:51:52
См. выше -1
17 October 2024, 16:51:55
См. выше -1
17 October 2024, 16:51:58
См. выше -1
