22 October 2026, 12:06:36
Камера Крис-П [Июнь 2017]
14 February 2016, 18:49:58
15 February 2016, 10:18:29
AlexandrCH, changed object latitude from 44.831986 to 44.831933
AlexandrCH, changed object longitude from 48.734738 to 48.734664
AlexandrCH, changed warning direction from 130 to 129.
AlexandrCH, changed object notification distance from 583 to 500.
15 February 2016, 10:19:24
Поставил на дорогу
10 June 2016, 19:41:59
stroy82, changed warning direction type from In a certain direction to Two directions.
10 June 2016, 19:42:22
10 June 2016, 19:43:05
stroy82, changed speed limit from 50 to 60.
stroy82, changed object description from 'Камера' to 'Камера Крис-П'.
10 June 2016, 19:43:23
Зачёт.
+1
29 June 2017, 11:13:03
Стоит только по утрам
21 October 2020, 19:36:56
изменилась схема движения, контроля в данном направлении больше нет -1
21 October 2020, 19:36:59
21 October 2020, 19:37:02
21 October 2020, 19:38:24
Timon34, changed object description from 'Камера Крис-П' to 'Камера Крис-П [Июнь 2017]'.
21 October 2020, 19:38:46
Timon34, changed object notification distance from 500 to 100.
23 October 2020, 18:06:16
23 October 2020, 18:06:27
23 October 2020, 18:06:32
23 October 2020, 18:21:44
По просьбе -1
23 October 2020, 18:21:49
По просьбе -1
23 October 2020, 18:21:54
По просьбе -1
