05 November 2026, 07:13:57
For the past 24 hours: 73 objects added, 87 objects edited, 18 objects removed.
Дядин
14 April 2012, 14:19:10
14 April 2012, 14:14:24
001mnb, changed object latitude from 40.528881 to 40.528796
001mnb, changed object longitude from 49.825640 to 49.825667
14 April 2012, 14:14:59
001mnb, changed object latitude from 40.528796 to 40.528794
14 April 2012, 14:15:32
001mnb, changed object latitude from 40.528794 to 40.528815
001mnb, changed object longitude from 49.825667 to 49.825626
14 April 2012, 14:15:47
001mnb, changed object latitude from 40.528815 to 40.528858
001mnb, changed object longitude from 49.825626 to 49.825584
11 August 2015, 19:09:48
silandser, changed object latitude from 40.528858 to 40.528723
silandser, changed object longitude from 49.825584 to 49.825963
11 August 2015, 19:10:38
Поставил по GPS http://mapcam.info/speedcam/point.php?idx=823312
24 August 2016, 11:24:40
silandser, changed object latitude from 40.528723 to 40.528621
silandser, changed object longitude from 49.825963 to 49.826001
silandser, changed object view angle from 20 to 45.
21 May 2023, 05:15:43
Пользователи сообщают что НП обозначен табличной на синем фоне?! Может кто то проезжал на данном участке дороги? А здесь обсуждение: https://mapcam.info/forum/index.php?topic=5.msg97935#msg97935 https://mapcam.info/forum/index.php?topic=41.msg97924#msg97924
15 June 2023, 19:06:51
15 June 2023, 19:07:05
См. Выше -1
15 June 2023, 19:07:07
См. Выше -1
15 June 2023, 19:07:10
См. Выше -1
15 June 2023, 19:29:58
silandser, changed object view angle from 45 to 10.
15 June 2023, 19:30:08
См.выше. Удалил. -1
15 June 2023, 19:30:09
См.выше. Удалил. -1
15 June 2023, 19:30:11
См.выше. Удалил. -1
