22 October 2026, 03:50:28
КРИС-С [70км 300м]
29 September 2011, 20:37:04
29 September 2011, 20:31:37
Камера №12 на карте http://maps.yandex.ru/?um=LnBt6IeIGxfJCSgFUuOlgb9OGHbnrirV&l=map
22 December 2011, 11:33:46
подтверждаю +1
10 April 2012, 13:26:20
dmitrij40, changed object latitude from 30.299332 to 30.296562
dmitrij40, changed object longitude from 59.822533 to 59.823907
11 April 2012, 10:55:25
dmitrij40, changed object description from 'Камера КРИС-С' to 'Камера КРИС-С. Контроль скорости.'.
27 August 2012, 20:10:47
yuryleb, changed object notification distance from 500 to 700.
08 June 2013, 23:54:02
Есть! +1
09 June 2013, 05:30:03
Дата съёмки 08.06.2013г.
22 March 2014, 00:37:23
Дата съёмки: 21.03.2014г.
15 October 2014, 14:00:43
valur111, changed object latitude from 30.296562 to 30.296724
valur111, changed object longitude from 59.823907 to 59.823806
valur111, changed warning direction from 133 to 135.
15 October 2014, 14:01:06
Чуть подправил по MCD.
30 May 2015, 20:48:05
      кс
30 May 2015, 22:17:13
Щито? :)
30 May 2015, 22:30:28
:-X Ждём месяцок... :)
17 June 2015, 18:34:38
Камеры вернули на место после ТО.
31 May 2015, 18:42:05
valur111, changed object latitude from 30.296724 to 30.296715
valur111, changed object longitude from 59.823806 to 59.823763
31 May 2015, 18:42:23
valur111, changed object view angle from 20 to 15.
05 October 2016, 22:33:10
      03.10.2016г. КРИС-С (4шт.).
08 November 2016, 01:24:59
КРИС-С, 110 км/ч.
КРИС-С, 110 км/ч.
08 November 2016, 01:26:34
Штрафует. +1
08 November 2016, 11:22:11
valur111, changed object description from 'Камера КРИС-С. Контроль скорости.' to 'КРИС-С, контроль скорости'.
11 December 2016, 20:43:31
yuryleb, changed object description from 'КРИС-С, контроль скорости' to 'КРИС-С'.
21 March 2018, 10:55:53
21 March 2018, 11:02:42
Написано: "От Пулковского к Дачному", а координаты  от idx=900059, которая "От Дачного к Пулковскому".. ???
14 May 2018, 05:52:57
20 September 2018, 14:09:16
20 September 2018, 14:09:31
прохоров, changed speed limit from 110 to 90.
08 October 2018, 20:51:42
19 October 2018, 21:00:15
Двухколёсным не актуально -1
28 October 2018, 16:07:17
См.выше. -1
04 November 2018, 18:59:25
Есть информация, что здесь от 70км. до 78км. внутреннего кольца устанавливают систему Бумеранг. Возьмите на контроль эти камеры.
08 November 2018, 12:47:43
Ошибся в направлении.
https://mapcam.info/speedcam/point.php?idx=900059#comment_2226884
15 January 2021, 11:59:48
valur111, changed object description from 'КРИС-С' to 'КРИС-С [70км 300м]'.
15 January 2021, 11:59:58
17 October 2022, 15:49:02
Пятый месяц отсутствуют какие-либо комплексы ФВФ. Кордон вместо КРИСов повесили на встречной опоре за постом ДПС. Как правильно поступать дальше с точкой? Всем месте обнулять рейтинг или удалять? Пока что переведу в тестовый режим.
17 October 2022, 18:16:56
Пока можно чуть снизить, думаю...
17 October 2022, 18:17:07
17 October 2022, 18:17:11
09 April 2023, 18:27:59
отсутствуют крисы уже давно -1
09 April 2023, 18:28:02
09 April 2023, 19:32:26
09 April 2023, 19:32:30
09 April 2023, 19:32:33
10 April 2023, 05:47:33
10 April 2023, 05:47:36
05 March 2024, 14:09:47
05 March 2024, 14:09:51
