22 October 2026, 13:24:28
Паук [937+400]
03 July 2017, 22:05:22
03 July 2017, 22:20:38
18 July 2017, 01:27:20
yohan, changed control area.
yohan, changed object description from 'Автодория' to 'Автодория [Каспий 938-933км]'.
24 July 2017, 18:01:16
yohan, changed object latitude from 44.268605 to 44.269275
yohan, changed object longitude from 48.913849 to 48.913272
12 October 2017, 17:32:43
12 October 2017, 17:47:59
штрафует, актуально +1
12 October 2017, 17:48:51
Timon34, changed object description from 'Автодория [Каспий 938-933км]' to 'Автодория [Р-22 Каспий 939-934км]'.
28 November 2017, 11:36:43
11 January 2018, 10:14:07
11 January 2018, 10:14:28
14 May 2018, 20:17:20
12 August 2018, 16:58:06
19 September 2018, 16:11:08
актуально - 12.9 ч.2 - превышение установленной скорости движения транспортного средства на величину более 20, но не более 40 км/ч +1
19 September 2018, 16:11:48
04 October 2018, 18:29:26
Для мото неактуально -1
04 October 2018, 18:36:11
Двухколёсным не актуально -1
04 October 2018, 19:19:34
08 May 2019, 15:33:55
02 March 2020, 14:04:12
02 March 2020, 14:04:35
см выше, демонтаж -1
02 March 2020, 14:04:38
02 March 2020, 15:16:45
по просьбе, смотреть выше -1
02 March 2020, 15:16:47
02 March 2020, 15:31:03
Ком выше -1
02 March 2020, 15:31:07
Ком выше -1
02 March 2020, 15:47:30
см выше 0 -1
07 June 2020, 17:19:36
07 June 2020, 17:19:42
07 June 2020, 17:19:46
24 September 2020, 12:28:22
Timon34, changed object latitude from 44.269275 to 44.262586
Timon34, changed object longitude from 48.913272 to 48.918354
24 September 2020, 12:39:53
Timon34, changed object latitude from 44.262586 to 44.257747
Timon34, changed object longitude from 48.918354 to 48.921971
24 September 2020, 12:40:05
Timon34, changed object latitude from 44.257747 to 44.252297
Timon34, changed object longitude from 48.921971 to 48.926059
24 September 2020, 12:40:34
Timon34, changed object latitude from 44.252297 to 44.252613
Timon34, changed object longitude from 48.926059 to 48.925858
24 September 2020, 12:40:54
Timon34, changed object description from 'Автодория [Р-22 Каспий 939-934км]' to 'Астра-Трафик'.
24 September 2020, 12:41:14
Актуализация в связи с установкой Астра-Трафик +1
24 September 2020, 12:41:17
24 September 2020, 12:41:20
24 September 2020, 12:47:33
Актуализировал +1
24 September 2020, 12:47:38
Актуализировал +1
25 September 2020, 17:59:49
Timon34, changed object latitude from 44.252613 to 44.252197
Timon34, changed object longitude from 48.925858 to 48.926174
25 September 2020, 18:08:43
Timon34, changed object description from 'Астра-Трафик' to 'Астра-Трафик [937км]'.
20 October 2020, 16:29:45
20 October 2020, 16:30:02
20 October 2020, 16:30:05
01 November 2021, 10:46:04
И эту Астру демонтировали. Не понятно, вернут или нет.
01 November 2021, 16:23:18
18 March 2025, 09:09:45
нужно отключить тест
18 March 2025, 09:07:36
, changed object latitude from 44.252197 to 44.259021
, changed object longitude from 48.926174 to 48.920997
, changed warning direction from 139 to 137.
, changed object description from 'Астра-Трафик [937км]' to 'Паук'.
18 March 2025, 09:08:14
, changed object latitude from 44.259021 to 44.260822
, changed object longitude from 48.920997 to 48.919629
18 March 2025, 09:08:47
Астру демонтировали, перенес на новое место
18 March 2025, 09:10:00
до штрафа -1
18 March 2025, 09:10:03
до штрафа -1
18 March 2025, 12:25:25
, changed object description from 'Паук' to 'Паук [937+400]'.
18 March 2025, 12:26:05
На зеркалах https://core-nmaps-mrc-browser.maps.yandex.ru/feature/2149538824/image В базе ГИБДД https://госавтоинспекция.рф/milestones/144212
19 March 2025, 16:40:05
, turned off test mode
