22 October 2026, 08:13:50
Арена
23 August 2011, 19:34:11
23 August 2011, 19:30:42
kurjanin, changed object latitude from 36.236349 to 36.236649
kurjanin, changed object longitude from 51.792273 to 51.792592
23 August 2011, 19:31:14
kurjanin, changed object latitude from 36.236649 to 36.236649
kurjanin, changed object description from 'Мобильная камера на земле под знаком' to 'Мобильная камера `Арена` на земле под знаком'.
24 August 2011, 03:15:12
если она мобильная - то точно не стационарная! это засада
24 August 2011, 14:12:47
kurjanin, changed object type from  Static speed camera Static speed camera to  Portable Camera (trap) Portable Camera (trap).
kurjanin, changed object description from 'Мобильная камера `Арена` на земле под знаком' to 'ЗАСАДА, мобильная камера `Арена` на земле под знаком'.
24 August 2011, 14:14:55
kurjanin, changed object description from 'ЗАСАДА, мобильная камера `Арена` на земле под знаком' to '`Арена` на земле под знаком'.
06 June 2014, 10:57:02
Подтверждаю. +1
20 January 2015, 11:43:23
deksven_dair, changed object description from '`Арена` на земле под знаком' to 'Арена'.
16 February 2015, 11:02:34
deksven_dair, changed object view angle from 17 to 20.
29 October 2015, 09:39:11
25 March 2018, 07:40:21
deksven_dair, changed object latitude from 36.236649 to 36.236252
deksven_dair, changed object longitude from 51.792592 to 51.792559
deksven_dair, changed warning direction type from Two directions to In a certain direction.
deksven_dair, changed warning direction from 26 to 32.
deksven_dair, changed object notification distance from 300 to 400.
06 September 2021, 18:19:15
Не актуально -1
06 September 2021, 18:19:18
Не актуально -1
06 September 2021, 18:19:20
Не актуально -1
