23 October 2026, 11:41:03
ВЗОР (тыл) [7км 890м - 6км 095м]
Russian Federation > Белгородская область
31 July 2019, 18:35:46
31 July 2019, 21:18:58
TTTT555, changed object latitude from 36.573514 to 36.573414
TTTT555, changed object longitude from 50.657663 to 50.657651
TTTT555, changed speed limit from 20 to 30.
TTTT555, changed speed limit from 0 to 20.
TTTT555, changed warning direction type from Two directions to In a certain direction.
TTTT555, changed warning direction from 81 to 100.
TTTT555, changed object notification distance from 500 to 350.
TTTT555, changed object view angle from 15 to 55.
TTTT555, changed object description from 'Объект добавлен с помощью программы MapcamDroid (offline)' to 'Все кольцо в ухабах'.
TTTT555, confirmed object added via Mapcam.info program
10 November 2020, 15:11:07
Не актуально -1
10 November 2020, 15:11:10
Не актуально -1
10 November 2020, 15:11:14
Не актуально -1
09 February 2021, 22:28:54
Не актуально -1
09 February 2021, 22:28:55
Не актуально -1
09 February 2021, 22:28:57
Не актуально -1
10 March 2021, 19:45:26
Timon34, changed object latitude from 36.573414 to 36.578856
Timon34, changed object longitude from 50.657651 to 50.651661
10 March 2021, 19:46:10
Timon34, changed object latitude from 36.578856 to 36.585744
Timon34, changed object longitude from 50.651661 to 50.648375
10 March 2021, 19:46:31
Timon34, changed object latitude from 36.585744 to 36.593068
Timon34, changed object longitude from 50.648375 to 50.645670
10 March 2021, 19:48:27
Timon34, changed object type from  Bad road ahead Bad road ahead to  Twin camera Twin camera.
Timon34, changed speed limit from 30 to 70.
Timon34, changed speed limit from 20 to 70.
Timon34, changed warning direction from 100 to 136.
Timon34, changed object notification distance from 350 to 170.
Timon34, changed object view angle from 55 to 25.
Timon34, changed object description from 'Все кольцо в ухабах' to 'ВЗОР (тыл) [7км 890м - 6км 095м]'.
10 March 2021, 19:48:43
Актуализация +1
10 March 2021, 19:48:45
Актуализация +1
10 March 2021, 19:48:47
Актуализация +1
10 March 2021, 21:16:50
см выше +1
10 March 2021, 21:16:54
см выше +1
10 March 2021, 21:16:55
см выше +1
21 September 2023, 21:14:21
точка не нужна, парной камеры нет -1
21 September 2023, 21:14:28
точка не нужна -1
21 September 2023, 21:14:30
точка не нужна -1
21 September 2023, 21:14:55
kenalog, changed object type from  Twin camera Twin camera to  Static speed camera Static speed camera.
kenalog, changed object notification distance from 170 to 100.
kenalog, changed object view angle from 25 to 10.
