22 October 2026, 08:13:59
АРЕНА (в боксе) [201км 380м]
Russian Federation > Алтайский край
07 April 2017, 10:08:42
07 April 2017, 14:18:49
silandser, changed object latitude from 83.921905 to 83.921755
silandser, changed object longitude from 53.462406 to 53.462387
silandser, changed warning direction from 145 to 142.
silandser, changed object notification distance from 209 to 360.
silandser, changed object view angle from 20 to 30.
07 April 2017, 14:19:14
silandser, changed object notification distance from 360 to 400.
silandser, changed object view angle from 30 to 35.
28 May 2018, 12:34:07
Primorets, changed object latitude from 83.921755 to 83.920239
Primorets, changed object longitude from 53.462387 to 53.464079
Primorets, changed warning direction from 142 to 147.
Primorets, changed object notification distance from 400 to 500.
Primorets, changed object view angle from 35 to 40.
Primorets, changed object description from 'Стационарный бокс под Арену' to 'АРЕНА (в антивандальном ящике) [201км 380м]'.
28 May 2018, 12:34:38
28 May 2018, 12:35:12
18 August 2018, 17:30:59
terminator090909, changed object notification distance from 500 to 1000.
terminator090909, changed object view angle from 40 to 30.
18 February 2019, 13:09:02
setpiton, changed warning direction from 147 to 144.
setpiton, changed object notification distance from 1000 to 660.
setpiton, changed object view angle from 30 to 40.
26 March 2019, 03:12:08
26 March 2019, 04:37:01
Мото ноль. -1
26 March 2019, 07:22:46
Primorets, changed speed limit from 90 to 70.
Primorets, changed object description from 'АРЕНА (в антивандальном ящике) [201км 380м]' to 'АРЕНА (в боксе) [201км 380м]'.
03 September 2019, 22:07:33
t828mm, changed speed limit from 90 to 70.
05 September 2019, 15:33:19
А легковым есть ограничение?
05 September 2019, 19:59:19
Знак общий.
19 January 2020, 04:53:25
прохоров, changed object type from  Static speed camera Static speed camera to  Integrated camera Integrated camera.
19 January 2020, 04:54:59
прохоров, changed object notification distance from 660 to 350.
19 January 2020, 04:55:17
прохоров, changed warning direction from 144 to 147.
прохоров, changed object view angle from 40 to 30.
26 March 2020, 10:39:01
На свежих снимках ящика не вижу
26 August 2021, 05:18:19
Камеру уже года 2 как убрали -1
26 August 2021, 05:18:24
26 August 2021, 06:42:41
26 August 2021, 06:42:44
26 August 2021, 06:42:47
26 August 2021, 06:43:33
Неактуально -1
26 August 2021, 06:43:37
Неактуально -1
26 August 2021, 07:09:19
Актуализация -1
