22 October 2026, 06:20:10
АЗИМУТ AZ350002, А-114 66км 630м
17 February 2020, 18:21:45
17 February 2020, 18:26:17
Tartar, changed speed limit from 80 to 90.
Tartar, changed speed limit from 0 to 90.
Tartar, changed warning direction from 112 to 114.
Tartar, changed object notification distance from 500 to 497.
Tartar, confirmed object added via Mapcam.info program
17 February 2020, 18:30:43
Хорошо бы фото камеры, это поможет идентифицировать ее модель и возможности
14 May 2020, 13:46:22
14 May 2020, 22:43:18
14 May 2020, 22:44:03
semaa1, changed object type from  Static speed camera Static speed camera to  Integrated camera Integrated camera.
semaa1, changed object notification distance from 497 to 500.
semaa1, changed object view angle from 15 to 20.
semaa1, changed object description from 'Объект добавлен с помощью программы MapcamDroid (offline)' to 'Встроенная камера'.
23 August 2020, 10:55:49
NikAndr, changed object description from 'Встроенная камера' to 'КРИС-П в ящике'.
NikAndr, changed camera model.
23 August 2020, 10:56:49
01.08.20: камера есть. РД пиликает.
23 August 2020, 10:57:26
23 August 2020, 10:59:14
Едем из Вологды.
04 August 2021, 12:54:19
Камера демонтирована.
05 August 2021, 09:43:56
Отсутствует -1
05 August 2021, 09:44:00
Отсутствует -1
05 August 2021, 09:44:03
Отсутствует -1
22 January 2022, 18:34:18
zubul, changed object latitude from 38.768314 to 38.773997
zubul, changed object longitude from 59.166227 to 59.164879
22 January 2022, 18:34:35
перенесена +1
22 January 2022, 18:34:38
перенесена +1
28 April 2022, 22:18:13
zubul, changed speed limit from 90 to 70.
07 May 2022, 17:02:21
Andrey35, changed object latitude from 38.773997 to 38.776851
Andrey35, changed object longitude from 59.164879 to 59.164445
Andrey35, changed control area.
Andrey35, changed control direction from Counter direction to In the back.
07 May 2022, 17:03:20
Andrey35, changed control direction from In the back to Both directions.
10 June 2022, 13:36:05
Демонтирована -1
10 June 2022, 13:36:09
Демонтирована -1
09 July 2022, 05:19:25
leshiy333, changed object latitude from 38.776851 to 38.773360
leshiy333, changed object longitude from 59.164445 to 59.165140
leshiy333, changed control area.
09 July 2022, 05:20:54
leshiy333, changed speed limit from 70 to 90.
09 July 2022, 06:15:01
Вернули +1
09 July 2022, 06:15:07
Вернули +1
09 July 2022, 06:15:15
Вернули +1
20 June 2023, 17:58:28
edu, changed object latitude from 38.773360 to 38.773794
edu, changed object longitude from 59.165140 to 59.165023
edu, changed control area.
20 June 2023, 17:58:51
edu, changed object latitude from 38.773793 to 38.774068
edu, changed object longitude from 59.165023 to 59.164935
06 May 2024, 13:18:03
, changed object latitude from 38.774068 to 38.774174
, changed object longitude from 59.164935 to 59.164856
06 May 2024, 13:24:44
28 July 2024, 15:45:33
28 July 2024, 15:45:45
едем из Вологды
18 September 2024, 13:53:07
, changed speed limit from 90 to 50.
, changed speed limit from 70 to 50.
09 June 2025, 11:09:13
, changed object latitude from 38.774174 to 38.774009
, changed object longitude from 59.164856 to 59.164993
10 June 2025, 07:19:54
, changed object description from 'КРИС-П в ящике' to 'АЗИМУТ AZ350002'.
23 June 2025, 03:20:45
, changed object description from 'АЗИМУТ AZ350002' to 'АЗИМУТ AZ350002, А-114 66км 640м'.
08 July 2025, 18:03:29
, changed object latitude from 38.774009 to 38.774361
, changed object longitude from 59.164993 to 59.164889
23 July 2025, 17:54:42
23 July 2025, 17:54:54
едем из Вологды
23 November 2025, 05:29:40
23 November 2025, 05:30:04
, changed object type from  Integrated camera Integrated camera to  Traffic control complex Traffic control complex.
09 April 2026, 16:43:44
, changed object description from 'АЗИМУТ AZ350002, А-114 66км 640м' to 'АЗИМУТ AZ350002, А-114 66км 630м'.
09 April 2026, 16:44:11
Так написано в штрафе.
09 April 2026, 16:59:11
09 April 2026, 16:59:45
Подтверждено штрафом +1
09 April 2026, 16:59:49
09 April 2026, 17:46:47
18 September 2026, 03:52:55
18 September 2026, 17:29:20
, changed object notification distance from 300 to 400.
18 September 2026, 17:29:59
30 September 2026, 10:06:28
