22 October 2026, 01:23:09
Автоураган
19 January 2020, 23:00:54
19 January 2020, 23:28:34
avivolga, changed object latitude from 39.242952 to 39.243226
avivolga, changed object longitude from 45.034850 to 45.034903
avivolga, changed speed limit from 0 to 40.
avivolga, changed warning direction type from Two directions to In a certain direction.
avivolga, changed object description from 'Объект добавлен с помощью программы MapcamDroid (offline)' to 'Камера на 40'.
avivolga, confirmed object added via Mapcam.info program
avivolga, changed camera model.
21 January 2020, 19:43:21
Тут случаем скорость не 70?
30 January 2020, 17:32:13
Сегодня проезжал. 70 км/ч, знак перед перекрестком, камера немного дальше. За перекрестком знаков ограничения скорости нет.
30 January 2020, 17:32:52
23REGION, changed speed limit from 40 to 70.
30 January 2020, 17:33:29
23REGION, changed object description from 'Камера на 40' to 'Автоураган'.
03 February 2020, 14:48:46
22 April 2020, 19:37:30
22 April 2020, 19:42:16
14 December 2023, 14:26:26
дорога реконструирована. рака и камера демонтированы. стоит разделительный бетонный забор. -1
10 January 2025, 15:42:34
Удаляю
14 December 2023, 14:26:29
25 January 2024, 12:47:55
См. выше. Удалил -1
25 January 2024, 12:47:58
См. выше. Удалил -1
25 January 2024, 12:48:01
См. выше. Удалил -1
