21 November 2026, 02:24:15
Лежачий полицеский
Belarus > Минская область
21 September 2014, 08:34:49
21 September 2014, 08:37:52
Дистанция для лп 150-300м в правилах прописано.
21 September 2014, 08:40:45
action_64, changed object notification distance from 500 to 200.
21 September 2014, 08:42:54
Спасибо, давно ничего не наносил и поэтому зыбыл! Извиняйте
21 September 2014, 19:45:53
Здесь два свежих "лежачих полицейских". В 5-10 метрах слева от перекрестка и в 5-10 метрах справа от него
22 September 2014, 06:14:12
Сегодня проеду там,посмотрю и добавлю и лежачих и ограничений скорости новых.
26 September 2014, 07:28:31
belkin, changed object latitude from 27.622633 to 27.622901
belkin, changed object longitude from 53.968488 to 53.968410
belkin, changed speed limit from 20 to 30.
belkin, changed warning direction type from Two directions to In a certain direction.
26 September 2014, 07:29:32
Т.к. неровности рядом, поставил одно направление - чтобы не засорять карту.
belkin, changed warning direction from 98 to 278.
belkin, changed object description from 'Лежачий полицеский по ГОСТ' to 'Лежачий полицеский'.
07 October 2014, 07:09:12
Barmaley_GMN, changed object latitude from 27.622901 to 27.622912
Barmaley_GMN, changed object longitude from 53.968410 to 53.968454
07 October 2014, 07:09:42
Перенёс на проезжую часть
29 September 2015, 12:33:16
Есть такой +1
18 May 2019, 17:05:35
Alissandru, changed speed limit from 30 to 40.
11 June 2019, 00:28:47
Alissandru, changed object notification distance from 200 to 100.
Alissandru, changed object view angle from 15 to 20.
13 October 2019, 07:37:26
Andrey80.by, changed object notification distance from 100 to 200.
14 December 2019, 16:06:41
14 December 2019, 16:06:44
14 December 2019, 16:06:47
14 December 2019, 16:12:30
14 December 2019, 16:12:34
14 December 2019, 16:12:39
14 December 2019, 16:42:24
Удаление -1
14 December 2019, 16:42:27
Удаление -1
14 December 2019, 16:42:29
Удаление -1
