22 October 2026, 09:31:56
Belarus > Витебская область
04 May 2011, 08:45:31
04 May 2011, 08:45:59
lsdim, changed warning direction type from All directions (360) to Two directions.
lsdim, changed warning direction from 0 to 126.
lsdim, changed object notification distance from 500 to 244.
lsdim, changed object view angle from 15 to 26.
21 August 2011, 08:16:49
Этот лежекоп направленный - изменить только в одну сторону -1
23 August 2011, 10:07:37
Надолго он здесь корни пустил +1
07 November 2011, 15:13:00
угол обзора бы побольше
10 November 2011, 18:54:57
lsdim, changed object latitude from 30.219127 to 30.219127
lsdim, changed object notification distance from 244 to 344.
lsdim, changed object view angle from 26 to 45.
13 November 2011, 15:37:44
wenrin, changed object latitude from 30.219127 to 30.219052
wenrin, changed object longitude from 55.202747 to 55.202649
wenrin, changed warning direction from 126 to 123.
wenrin, changed object notification distance from 344 to 250.
wenrin, changed object view angle from 45 to 20.
18 November 2011, 19:38:35
согласен с mixdm 2011 -   Этот лежекоп направленный - изменить только в одну сторону -1
18 December 2011, 16:42:33
Этот лежекоп наверное теперь здесь навсегда :( +1
09 July 2012, 05:19:01
mixdm, changed object latitude from 30.219052 to 30.218982
mixdm, changed object longitude from 55.202649 to 55.202551
mixdm, changed speed limit from 40 to 20.
mixdm, changed warning direction type from Two directions to In a certain direction.
mixdm, changed warning direction from 123 to 299.
mixdm, changed object description from 'лежачий полиц' to 'Уточнение местоположения на дороге, изменение на однонаправленный'.
09 July 2012, 05:54:34
mixdm, changed object notification distance from 250 to 300.
mixdm, changed object description from 'Уточнение местоположения на дороге, изменение на однонаправленный' to 'Лежачий полицейский'.
09 July 2012, 06:03:10
mixdm, changed object notification distance from 300 to 250.
mixdm, changed object view angle from 20 to 15.
09 July 2012, 10:31:11
mixdm, changed object latitude from 30.218982 to 30.218966
mixdm, changed object longitude from 55.202551 to 55.202545
09 July 2012, 11:03:06
mixdm, changed warning direction from 299 to 292.
04 December 2012, 18:24:32
mixdm, changed warning direction from 292 to 298.
17 September 2015, 09:00:42
mixdm, changed warning direction from 298 to 300.
26 July 2019, 20:51:13
mixdm, changed object notification distance from 250 to 200.
03 July 2026, 17:38:46
На удаление, поставили светофор для пешеходов, лежекоп ликвидирован -1
03 July 2026, 17:38:51
03 July 2026, 17:38:55
04 July 2026, 10:51:58
04 July 2026, 10:52:01
04 July 2026, 10:52:03
04 July 2026, 10:52:14
04 July 2026, 12:57:11
Отсутствует -1
04 July 2026, 12:57:14
Отсутствует -1
04 July 2026, 12:57:16
Отсутствует -1
