18 October 2026, 01:28:45
For the past 24 hours: 68 objects added, 32 objects edited, 5 objects removed.
Стрелка-Плюс (тыл)
26 December 2013, 14:32:45
26 December 2013, 15:09:20
KiLLer13, changed speed limit from 10 to 60.
KiLLer13, changed warning direction type from Two directions to In a certain direction.
KiLLer13, changed object description from 'Объект добавлен с помощью программы MapcamDroid (on-line)' to 'Стрелка-СТ'.
KiLLer13, confirmed object added via Mapcam.info program
27 December 2013, 08:16:17
KiLLer13, changed object latitude from 37.698592 to 37.698554
KiLLer13, changed object longitude from 55.635055 to 55.634949
KiLLer13, changed warning direction from 306 to 308.
KiLLer13, changed object view angle from 15 to 11.
29 December 2013, 18:53:08
+1 видел +1
08 January 2014, 19:55:29
разве не 80?
13 January 2014, 09:28:41
там 80 можно.
15 January 2014, 06:48:14
Точно?
15 January 2014, 19:14:07
точно 80, как и по всему каширскому шоссе, достал уже мапкам пикать(( поправьте, кто знающий, на протяжении всего каширского шоссе 80 кмч
16 January 2014, 05:30:06
KiLLer13, changed speed limit from 60 to 80.
16 January 2014, 05:30:25
Изменил до 80 км/ч.
25 January 2014, 21:01:58
Johannes, changed object latitude from 37.698554 to 37.698500
Johannes, changed object longitude from 55.634949 to 55.634900
Johannes, changed object notification distance from 500 to 700.
Johannes, changed object view angle from 11 to 15.
Johannes, changed object description from 'Стрелка-СТ' to 'Стрелка-СТ (по GPS)'.
25 January 2014, 21:04:24
Точка снята автором практически по факту, респект!
Незначительно поправил по GPS без привязки к OSM.
Дистанцию увеличил исходя из скоростного ограничения 80 км/ч, чтобы успеть сбросить скорость.
23 June 2014, 17:13:09
Контроль полосы общественного транспорта. Проверено.
24 June 2014, 04:33:37
Пришло письмо счастья?
13 November 2014, 12:22:05
Пришло((
25 March 2015, 21:28:49
05 November 2015, 22:17:49
, changed object latitude from 37.698500 to 37.698532
, changed object longitude from 55.634900 to 55.634936
, changed warning direction from 308 to 306.
, changed object notification distance from 700 to 500.
05 November 2015, 22:18:05
500 метров достаточно ! Если кому надо, то в программе есть настройки для увеличения дистанции, а то лишний шум надоел !
06 November 2015, 08:17:58
Не рекомендую крутить эту настройку в MCD. Если в MCD изменить с рекомендуемой дистанции оповещения на определенную, то ложных срабатываний будет еще больше.
31 December 2015, 18:37:07
31 December 2015, 18:37:36
Speed.
Speed.
10 January 2016, 00:13:26
Тут ещё и полоса в работе:
10 January 2016, 00:13:42
10 January 2016, 00:14:14
Полоса ОТ.
Полоса ОТ.
01 March 2016, 13:08:33
31 May 2016, 07:24:38
31 May 2016, 07:25:12
02 July 2016, 09:33:43
12 August 2016, 22:51:27
Johannes, changed additional information (RU): \"
12 August 2016, 22:54:15
Johannes, changed object notification distance from 500 to 600.
23 August 2016, 23:27:26
Johannes, changed object type from  Static speed camera Static speed camera to  Traffic control complex Traffic control complex.
23 August 2016, 23:27:33
Для iOS МФК должен отображаться в программе как тип 1.
Поменялось предупреждение и для Андроида.
Потому данная точка уже не может быть типом "камеры фиксации скорости", она контролирует несколько нарушений, потому теперь это тип МФК.
30 August 2016, 20:30:33
может стоит по аналогии с предыдущей камерой поставить ограничение 60?
31 August 2016, 08:34:23
KiLLer13, changed speed limit from 80 to 60.
31 August 2016, 08:35:01
По аналогии с https://mapcam.info/speedcam/point.php?idx=389665 поставил 60
11 September 2016, 08:45:38
11 September 2016, 08:46:10
26 October 2016, 21:31:48
В обратном направлении тоже 60 или 80? Там все точки 80
27 October 2016, 10:02:55
В центр 80, без изменений.
11 February 2017, 14:15:20
Есть подтверждения о штрафах 81+км/ч? Или как бывало, знак 60, а настроена по прежнему на 80?
13 May 2017, 10:00:52
, changed object description from 'Стрелка-СТ (по GPS)' to 'Стрелка-СТ'.
24 January 2018, 22:41:18
24 January 2018, 22:41:32
05 June 2018, 16:42:29
02 September 2018, 15:26:47
Перед камерой (метров 50) установили знак ограничение скорости 50 км/ч
03 September 2018, 09:24:35
Случайно не на дублёре для съезжающих?
05 September 2018, 04:32:50
НЕт, знак на основном ходу!
и знак искусственных неровностей.
Там шумовую разметку нанесли, видимо под это,
или камера стала дохода мало приносить.
05 September 2018, 11:21:25
Принято.
23 September 2018, 13:10:33
24 September 2018, 17:57:25
16 October 2018, 14:27:39
знак есть на 50, но лучше подождать реальных штрафов, неделю назад ехал там 75 в час тфу тфу без штрафов, а значит камера на 60
12 November 2018, 09:30:07
Спасибо.
27 January 2019, 12:10:35
04 April 2019, 18:33:38
29 April 2019, 05:57:57
, changed object notification distance from 600 to 500.
29 April 2019, 05:58:31
Убрал наложение на АУ.
15 June 2019, 09:57:15
Перед камерой поставили знак 50. Не знаю, ловит уже за это или ещё нет. Но надо быть готовым. :-(
28 June 2019, 06:34:12
28 June 2019, 06:34:19
15 July 2019, 07:04:20
serezhka, changed speed limit from 60 to 50.
15 July 2019, 12:57:13
15 July 2019, 13:02:54
Спасибо
07 August 2019, 00:20:17
Похоже, поменяли ей направление. Теперь смотрит в спину.
07 August 2019, 00:37:43
15 August 2019, 21:26:56
Спасибо плюс
15 August 2019, 21:37:41
Zenduri, changed control area.
Zenduri, changed object notification distance from 500 to 400.
Zenduri, changed object description from 'Стрелка-СТ' to 'Стрелка-СТ (тыл)'.
Zenduri, changed additional information (RU): \"
15 August 2019, 21:41:28
15 August 2019, 21:42:46
Для мото актуально плюс 2. Теперь камера смотрит в тыл.!
16 August 2019, 05:39:33
15 November 2019, 18:16:15
18 November 2019, 19:49:41
Актуальна.
25 November 2019, 16:33:43
25 November 2019, 16:34:06
27 November 2019, 18:00:42
10 January 2020, 13:52:34
Штраф.
22 May 2020, 06:13:19
04 October 2020, 16:12:56
04 October 2020, 16:19:08
30 March 2021, 12:02:27
17 January 2022, 09:56:41
balabol.1974, changed object description from 'Стрелка-СТ (тыл)' to 'https://mapcam.info/speedcam/point.php?idm=TksQij0rGg-'.
17 January 2022, 09:57:50
balabol.1974, changed object description from 'https://mapcam.info/speedcam/point.php?idm=TksQij0rGg-' to 'МУЛЯЖ! Стрелка-СТ (рейтинг ноль)'.
17 January 2022, 09:58:31
В базе нет! Рейтинг ноль. -1
17 January 2022, 09:58:35
17 January 2022, 09:58:39
17 January 2022, 18:31:49
ком вверху -1
17 January 2022, 18:31:53
ком вверху -1
17 January 2022, 18:31:56
ком вверху -1
16 February 2023, 05:59:40
kroxan, changed control area.
kroxan, changed control direction from In the back to Counter direction.
kroxan, changed object notification distance from 400 to 100.
kroxan, changed object view angle from 15 to 10.
kroxan, changed object description from 'МУЛЯЖ! Стрелка-СТ (рейтинг ноль)' to 'демонтаж'.
16 February 2023, 06:00:00
16 February 2023, 06:00:05
16 February 2023, 06:00:10
15 May 2023, 12:45:12
42OI339O, changed control area.
42OI339O, changed control direction from Counter direction to In the back.
42OI339O, changed object notification distance from 100 to 250.
42OI339O, changed object view angle from 10 to 15.
42OI339O, changed object description from 'демонтаж' to 'Стрелка-Плюс (тыл)'.
42OI339O, changed camera model.
42OI339O, changed additional information (RU): \"
15 May 2023, 12:45:42
новая Стрелка +1
15 May 2023, 12:45:48
новая Стрелка +1
15 May 2023, 12:45:53
новая Стрелка +1
15 May 2023, 12:46:40
42OI339O, changed object type from  Static speed camera Static speed camera to  Lane Control Camera Lane Control Camera.
42OI339O, changed speed limit from 50 to 60.
15 May 2023, 12:49:46
42OI339O, changed speed limit from 60 to 50.
16 May 2023, 03:51:42
выше +1
16 May 2023, 03:51:48
выше +1
16 May 2023, 03:51:53
выше +1
07 August 2023, 06:08:33
проезжаю 75-78 регулярно, она не на 50!
07 August 2023, 16:47:54
Она возможно скорость и не пасёт. А этот знак на месте? https://yandex.ru/maps/-/C2u35nD
07 August 2023, 18:23:01
знак стоит, а писк от камеры не нужен совсем.
28 January 2024, 09:00:22
, changed object type from  Lane Control Camera Lane Control Camera to  Red light detection camera Red light detection camera.
31 December 2024, 13:28:31
31 December 2024, 13:28:55
31 December 2024, 13:28:59
31 December 2024, 13:29:03
23 January 2025, 07:54:40
08 April 2025, 10:53:39
Лупит в спину за скорость свыше  50 км/ч , проверено штрафом за 73 км прилетел.
14 May 2025, 09:57:41
11 June 2025, 07:41:47
Просьба добавить в информацию для водителя скорость.
11 June 2025, 12:10:21
Сделано.
11 June 2025, 12:09:52
07 October 2025, 20:00:20
18 April 2026, 07:50:22
прилетело сегодня за скорость 50 в спину с этой камеры координаты в фото 55.634772, 37.698709  Каширское 80Д и номер sp03821120z причем он в яндексе почему то на катукова стоит. фото не могу приложить по тех причинам.
18 April 2026, 07:50:26
19 April 2026, 07:06:52
В яндексе старая информация.
