22 October 2026, 12:52:38
26 September 2012, 14:59:25
30 September 2012, 10:55:44
crazyden, changed speed limit from 30 to 20.
crazyden, confirmed object added via Mapcam.info program
02 October 2012, 10:10:06
леха150, changed object latitude from 37.627357 to 37.627358
леха150, changed warning direction from 86 to 90.
леха150, changed object notification distance from 500 to 150.
леха150, changed object description from 'Объект добавлен с помощью программы MapcamDroid (on-line)' to 'Лежачий полицейский'.
02 October 2012, 10:11:51
Правее 120м на общей карте есть уже лежачий -Ваш не дубль?В данном месте два леж.полицейских?
07 July 2020, 18:06:53
Нет ЛП -1
07 July 2020, 18:06:59
Нет ЛП -1
07 July 2020, 18:07:03
Нет ЛП -1
07 July 2020, 18:11:41
См выше.Удалил -1
07 July 2020, 18:11:44
См выше.Удалил -1
07 July 2020, 18:11:46
См выше.Удалил -1
08 July 2020, 21:21:32
setpiton, changed object notification distance from 150 to 100.
setpiton, changed object view angle from 15 to 10.
