22 October 2026, 10:44:06
Пешеходный переход
19 July 2010, 07:39:56
23 August 2010, 11:05:15
25 June 2011, 09:44:40
Не знаю из каких соображений Вы поставили две точки, но может все-таки одну и двунаправленную и именно "Пешеходный переход"
27 June 2011, 08:46:24
Crimzic, changed speed limit from 90 to 70.
15 December 2012, 15:21:24
почему 70, если там участок, на который распространяется действие 60?
Crimzic, changed warning direction type from In a certain direction to Two directions.
Crimzic, changed object notification distance from 500 to 559.
27 June 2011, 08:47:03
NickF, спасибо за замечания. Объект был изменён.
27 September 2011, 12:16:06
, changed object latitude from 46.152953 to 46.152953
, changed object type from  Other danger Other danger to  School Zone / Dangerous pedestrians crossing School Zone / Dangerous pedestrians crossing.
26 March 2013, 06:18:05
Dmir21, changed object latitude from 46.152953 to 46.152800
26 March 2013, 06:18:06
Dmir21, changed object longitude from 51.603765 to 51.603819
Dmir21, changed object notification distance from 559 to 500.
28 May 2018, 08:48:53
Насколько эта точка актуальна?
28 May 2018, 08:50:47
прохоров, changed speed limit from 70 to 60.
06 January 2021, 18:03:50
достаточно рейтинга 1 -1
06 January 2021, 18:03:54
06 January 2021, 18:03:57
06 January 2021, 18:05:41
ой, тут вообще построен НАДземный переход - под удаление!
06 January 2021, 18:08:51
См...выше -1
06 January 2021, 18:08:55
См...выше -1
06 January 2021, 18:08:58
См...выше -1
06 January 2021, 18:10:25
06 January 2021, 19:20:38
См выше. Удалил -1
06 January 2021, 19:20:42
См выше. Удалил -1
06 January 2021, 19:20:45
См выше. Удалил -1
