22 October 2026, 06:20:00
КОРДОН
22 October 2019, 11:17:46
22 October 2019, 11:19:03
Фото камеры пока нет, но есть штраф, судя по фото, камера на столбе.
22 October 2019, 11:21:27
n51.684743,e39.228825
22 October 2019, 11:21:58
Valfon, changed object latitude from 39.228691 to 39.228825
Valfon, changed object longitude from 51.685145 to 51.684743
22 October 2019, 11:22:39
Valfon, changed warning direction from 181 to 186.
Valfon, changed object notification distance from 250 to 249.
Valfon, changed object view angle from 25 to 31.
22 October 2019, 11:24:10
Valfon, changed warning direction from 186 to 187.
Valfon, changed object notification distance from 249 to 285.
23 October 2019, 05:17:06
Yald, changed object notification distance from 285 to 350.
Yald, changed object view angle from 31 to 30.
Yald, changed camera model.
23 October 2019, 05:17:18
Мото-рейтинг ноль. -1
30 December 2019, 12:20:52
10 October 2020, 12:34:41
silandser, changed object notification distance from 350 to 400.
silandser, changed object view angle from 30 to 45.
10 October 2020, 12:43:26
24 January 2021, 12:05:58
24 January 2021, 12:06:11
штраф +1
24 January 2021, 12:06:14
штраф +1
27 May 2022, 09:46:42
27 May 2022, 09:46:57
Убрали камеру. Точка в "Тест"
02 June 2022, 10:55:51
Камера отсутствует -1
02 June 2022, 10:55:55
02 June 2022, 10:55:59
02 June 2022, 15:05:16
Автор давно не активен. Может обнулить ?.
02 June 2022, 17:13:43
Надо удалять.
02 June 2022, 18:39:52
См выше. На удаление -1
02 June 2022, 18:39:55
19 June 2022, 03:44:21
Отсутствует -1
19 June 2022, 03:44:25
Отсутствует -1
27 June 2022, 19:51:06
silandser, changed object notification distance from 400 to 100.
silandser, changed object view angle from 45 to 10.
