22 October 2026, 06:19:55
22 July 2021, 02:25:59
22 July 2021, 10:01:49
oloolo2013, changed object type from  Bad road ahead Bad road ahead to  Speed Bump Speed Bump.
oloolo2013, changed speed limit from 10 to 20.
oloolo2013, changed speed limit from 0 to 30.
oloolo2013, changed object notification distance from 500 to 300.
oloolo2013, confirmed object added via Mapcam.info program
22 July 2021, 16:17:06
Timon34, changed object notification distance from 300 to 100.
Timon34, changed object description from 'Объект добавлен 2021-07-22 02:25:56 с помощью MapcamDroid' to 'Лежачий полицейский'.
13 September 2021, 12:49:19
Автор, этот участок с лежаками обозначен крайними точками с указанием их количества. Сейчас при проезде участка идет каша из ЛП.
02 July 2022, 20:06:11
Без реакции автора. На удаление -1
02 July 2022, 20:06:14
02 July 2022, 20:06:16
07 July 2022, 13:56:18
07 July 2022, 13:56:27
07 July 2022, 13:56:31
07 July 2022, 18:26:47
