22 October 2026, 10:14:27
МУЛЯЖ! Арена, рейтинг ноль
Russian Federation > Брянская область
02 June 2021, 16:56:27
03 June 2021, 14:06:41
DiK57, changed speed limit from 0 to 60.
DiK57, changed warning direction type from Two directions to In a certain direction.
DiK57, changed warning direction from 46 to 48.
DiK57, changed object notification distance from 500 to 300.
DiK57, changed object view angle from 15 to 20.
DiK57, changed object description from 'Объект добавлен 2021-06-02 16:56:24 с помощью MapcamDroid' to 'Арена'.
DiK57, confirmed object added via Mapcam.info program
DiK57, changed camera model.
03 June 2021, 15:12:22
03 June 2021, 15:31:32
DiK57, changed object notification distance from 300 to 200.
DiK57, changed object description from 'Арена' to 'Муляж Арена'.
03 June 2021, 15:32:24
DiK57, changed object description from 'Муляж Арена' to 'Муляж Арена рейтинг 0'.
03 June 2021, 15:35:04
Понизте рейтинг до 0
03 June 2021, 15:45:15
муляж -1
03 June 2021, 15:45:22
муляж -1
09 June 2021, 19:41:36
леха150, changed warning direction from 48 to 52.
леха150, changed object description from 'Муляж Арена рейтинг 0' to 'МУЛЯЖ! Арена, рейтинг ноль'.
14 June 2021, 12:03:24
DiK57, changed object latitude from 32.261302 to 32.261323
DiK57, changed object longitude from 52.755244 to 52.755226
14 June 2021, 12:03:41
DiK57, changed object notification distance from 200 to 150.
26 April 2022, 07:28:25
Камеры и как такового мулежа тоже нет.
26 April 2022, 07:31:16
На майских проверю лично, если нет то удалю.
30 April 2022, 17:05:13
Убрали его. Удаляю.
