23 October 2026, 16:21:15
Автодория 3.5
23 August 2013, 16:59:56
23 August 2013, 17:08:46
benyamin, changed object latitude from 49.112450 to 49.112429
benyamin, changed object longitude from 55.819336 to 55.819432
benyamin, changed warning direction from 269 to 91.
benyamin, changed object notification distance from 500 to 200.
benyamin, changed object description from 'Объект добавлен с помощью программы Mapcam IOS (on-line)' to 'КПИС-П'.
benyamin, confirmed object added via Mapcam.info program
24 August 2013, 05:23:57
Baz, changed object description from 'КПИС-П' to 'КРИС-П'.
24 August 2013, 05:24:36
Исправьте значение скорости. 56 км/ч - такого ограничения не бывает
24 August 2013, 06:33:53
Да действительно, видимо программа фиксирует текущую скорость передвижения в момент добавления точки
25 August 2013, 04:41:06
так точно :)
24 August 2013, 06:32:47
benyamin, changed speed limit from 56 to 60.
14 December 2014, 07:02:58
эта камера направлена в спину
22 December 2014, 06:21:55
и? вы хотите оповещение, после того как ее проедите?
06 May 2015, 07:35:19
benyamin, changed object description from 'КРИС-П' to 'Камера фиксации скорости (КРИС-П)'.
11 November 2015, 13:14:54
15 September 2016, 16:51:27
ILineho, changed object notification distance from 200 to 500.
ILineho, changed object description from 'Камера фиксации скорости (КРИС-П)' to 'Крис-П'.
21 September 2016, 09:43:52
benyamin, changed object description from 'Крис-П' to 'Камера фиксации скорости (КРИС-П)'.
08 July 2020, 18:48:40
УльяновскGSM, changed object description from 'Камера фиксации скорости (КРИС-П)' to 'Кордон-Темп'.
08 July 2020, 19:39:43
Полоса и скорость
08 July 2020, 18:50:14
08 July 2020, 19:31:33
Подтверждено штрафом +1
08 July 2020, 19:31:50
08 July 2020, 19:32:44
29 July 2023, 23:21:40
djdredd, changed object notification distance from 500 to 300.
29 July 2023, 23:23:22
djdredd, changed warning start time from 0 to 6.
djdredd, changed warning end time from 24 to 22.
04 February 2025, 04:31:34
Зачем это?
04 February 2025, 04:35:43
Увидел
03 February 2025, 15:36:56
, changed object latitude from 49.112429 to 49.113572
, changed object longitude from 55.819432 to 55.819432
, changed object type from  Рossible mobile police post. (focus on speed!) Рossible mobile police post. (focus on speed!) to  Static speed camera Static speed camera.
, changed warning direction from 91 to 90.
, changed object description from 'Кордон-Темп' to 'Автодория 3.5'.
, changed warning start time from 6 to 0.
, changed warning end time from 22 to 24.
04 February 2025, 04:32:06
Завышен -1
04 February 2025, 04:32:09
Завышен -1
04 February 2025, 04:32:12
Завышен -1
04 February 2025, 04:32:23
03 May 2025, 12:21:48
03 May 2025, 13:35:18
03 May 2025, 13:35:29
подтверждено +1
04 May 2025, 16:47:25
спасибо
03 May 2025, 13:35:31
подтверждено +1
