21 September 2026, 19:46:09
Зелёный
24 July 2015, 11:50:11
25 July 2015, 20:19:02
1UMKa, changed speed limit from 80 to 60.
1UMKa, changed warning direction type from Two directions to In a certain direction.
1UMKa, changed object description from 'Объект добавлен с помощью программы MapcamDroid (on-line)' to 'Новая Купавна '.
1UMKa, confirmed object added via Mapcam.info program
25 July 2015, 21:08:51
silandser, changed object view angle from 15 to 45.
25 July 2015, 21:09:07
Для оповещения о конце НП
07 August 2015, 09:13:42
, changed object description from 'Новая Купавна ' to 'Зелёный'.
19 January 2016, 09:47:35
NightWatcher, changed object latitude from 38.091275 to 38.091296
NightWatcher, changed object longitude from 55.811087 to 55.811054
22 August 2016, 06:34:02
Вот это угол!!! Всем углам, угол))))))
22 August 2016, 07:25:05
Угол на основе тестов для отработки сообщения о КНП без дополнительной точки на дорогах с разнесенными проезжими частями
04 February 2018, 13:48:32
Hyundi505, changed object latitude from 38.091296 to 38.090594
Hyundi505, changed object longitude from 55.811054 to 55.810981
04 February 2018, 13:49:05
Актуализация
