23 October 2026, 05:53:05
05 September 2015, 10:27:31
10 September 2015, 19:38:09
РЃ-РњРѕРЃ, changed speed limit from 80 to 90.
РЃ-РњРѕРЃ, changed warning direction type from Two directions to In a certain direction.
РЃ-РњРѕРЃ, changed object description from 'Объект добавлен с помощью программы MapcamDroid (on-line)' to 'Мобильная стрелка'.
РЃ-РњРѕРЃ, confirmed object added via Mapcam.info program
10 September 2015, 19:38:23
РЃ-РњРѕРЃ, changed object type from  Static speed camera Static speed camera to  Portable Camera (trap) Portable Camera (trap).
26 September 2015, 08:41:31
06 November 2015, 13:20:50
, changed object description from 'Мобильная стрелка' to 'Стрелка-М'.
21 November 2015, 14:36:18
13 August 2016, 20:19:12
14 August 2016, 14:27:20
Плюс за актуализацию.
15 September 2016, 14:20:22
Удалите точку - дубль ранее созданной https://mapcam.info/speedcam/point.php?idx=742953
Фото можно продублировать туда.
15 September 2016, 14:33:23
Разверните направления и поставьте на место IDX: 964239, а самую свежую точку на удаление. Так будет правильно. Спасибо за понимание.
15 September 2016, 15:58:58
2maxic, changed object latitude from 36.907342 to 36.906388
2maxic, changed object longitude from 55.457168 to 55.456579
2maxic, changed warning direction from 224 to 44.
2maxic, changed object notification distance from 500 to 600.
29 January 2017, 12:11:51
, changed object latitude from 36.906388 to 36.912139
, changed object longitude from 55.456579 to 55.459901
, changed warning direction from 44 to 43.
, changed object notification distance from 600 to 602.
29 January 2017, 12:16:27
29 January 2017, 12:16:38
29 January 2017, 12:17:34
Актуально. +1
29 January 2017, 12:21:41
, changed object latitude from 36.912139 to 36.909864
, changed object longitude from 55.459901 to 55.458602
, changed object notification distance from 602 to 600.
25 March 2017, 12:58:03
, changed object latitude from 36.909864 to 36.913641
, changed object longitude from 55.458602 to 55.460853
25 March 2017, 12:59:14
25 March 2017, 12:59:24
25 March 2017, 13:00:37
, changed object notification distance from 600 to 550.
06 April 2018, 08:11:53
18 April 2018, 07:39:08
Теперь фургон зелёного цвета.
18 April 2018, 08:33:37
13 September 2018, 13:35:12
13 September 2018, 21:19:28
30 September 2018, 09:56:24
Фото 29_09_2018
Фото 29_09_2018
30 September 2018, 10:16:03
Спасибо. Пора Вам +5 иметь. Поздравляю!
08 November 2018, 10:31:22
это в тыл из Москвы
это в тыл из Москвы
15 January 2019, 06:35:31
, changed object description from 'Стрелка-М' to 'Стрелка-М (58км 600м)'.
06 March 2020, 19:27:25
Подтверждено 2020-02-29 12:05:01 (UTC±00:00)
     Вероятность: 40 %  (Частота за прошлый месяц)
12 July 2024, 11:09:53
, changed object description from 'Стрелка-М (58км 600м)' to 'архив'.
12 July 2024, 11:10:19
НЕТ В БАЗЕ -1
12 July 2024, 11:10:22
НЕТ В БАЗЕ -1
12 July 2024, 11:10:25
НЕТ В БАЗЕ -1
13 July 2024, 19:13:25
выше -1
13 July 2024, 19:13:28
выше -1
13 July 2024, 19:13:31
выше -1
13 July 2024, 19:14:01
, changed object notification distance from 550 to 100.
13 July 2024, 19:40:10
См выше.Удалил -1
13 July 2024, 19:40:12
См выше.Удалил -1
13 July 2024, 19:40:13
См выше.Удалил -1
