23 October 2026, 12:22:29
Стрелка-М-В (тыл)
31 March 2021, 12:20:43
31 March 2021, 12:21:47
Zuko95, changed warning direction from 0 to 150.
21 April 2021, 19:21:25
balabol.1974, changed object latitude from 37.578329 to 37.578320
balabol.1974, changed object longitude from 55.734407 to 55.734424
balabol.1974, changed speed limit from 60 to 40.
balabol.1974, changed warning direction from 150 to 146.
balabol.1974, changed object notification distance from 500 to 250.
balabol.1974, changed object description from 'Камера на против посольства' to 'Стрелка-М-П (тыл)'.
21 April 2021, 19:50:17
14 June 2021, 15:42:59
14 June 2021, 15:45:36
Zyma, changed object latitude from 37.578320 to 37.578744
Zyma, changed object longitude from 55.734424 to 55.734065
Zyma, changed control area.
Zyma, changed warning direction from 146 to 326.
Zyma, changed object notification distance from 250 to 100.
Zyma, changed object view angle from 20 to 15.
14 June 2021, 19:21:02
14 June 2021, 19:32:49
balabol.1974, changed object latitude from 37.578744 to 37.578612
balabol.1974, changed object longitude from 55.734065 to 55.734111
balabol.1974, changed object type from   to  Other danger Other danger.
balabol.1974, changed object view angle from 15 to 50.
14 June 2021, 19:33:07
balabol.1974, changed object type from  Other danger Other danger to  Lane Control Camera Lane Control Camera.
14 June 2021, 20:11:13
balabol.1974, changed speed limit from 40 to 10.
14 June 2021, 20:17:00
Данная камера фиксирует стоп-линию, соответственно в настройках камеры надо отмечать скорость 0 км. Даже минимальная скорость 10 км/ч вводит водителя в заблуждение.
17 September 2021, 03:49:18
17 September 2021, 06:42:07
Подтверждено штрафом +1
17 September 2021, 06:42:09
17 September 2021, 06:42:11
17 September 2021, 21:08:27
18 September 2021, 06:12:40
А кто-то пытался подобное опротестовывать? Просто стало интересно, решил произвести расчеты. Скорость на первом фото 21 км/ч, на втором 20, возьмем усредненную - 20,5 км/ч. Время между первым кадром и вторым без тысячной доли 1,2 секунды. Получаем, что автомобиль должен был без остановки проехать за это время 6,833 метра. Но длина авто на фото явно не может быть такого значения (на первом фото он находится точно перед стоп-линией, на втором сразу после нее). Т.е., авто сдвинулся на корпус (примерно 4,4 метра) а без остановки должен был бы быть уже за ПП.
18 September 2021, 08:24:49
Здесь, насколько я понял, стоп-линия...
18 September 2021, 08:30:22
И должна быть остановка (лимитированное по времени отсутствие движения ?) а не медленное движение.
18 September 2021, 10:59:38
И при установке предупреждения надо, чтобы было 0 км/ч. А не как сейчас я делаю минимальную скорость 10.
18 September 2021, 11:03:21
balabol.1974, changed object description from 'Стрелка-М-П (тыл)' to 'Стрелка-М-В (тыл)'.
04 February 2022, 19:02:25
18 May 2022, 05:33:37
ДЕМОНТАЖ -1
18 May 2022, 05:33:40
ДЕМОНТАЖ -1
18 May 2022, 05:33:43
ДЕМОНТАЖ -1
18 May 2022, 05:44:47
Выше -1
18 May 2022, 05:44:50
Выше -1
18 May 2022, 05:44:53
Выше -1
18 May 2022, 13:07:22
Демонтаж. -1
18 May 2022, 13:07:25
Демонтаж. -1
18 May 2022, 13:07:28
Демонтаж. -1
18 May 2022, 13:47:24
balabol.1974, changed object view angle from 50 to 10.
18 May 2022, 13:47:54
ПРОСЬБА УДАЛИТЬ С КАРТЫ
