23 October 2026, 02:19:11
Стрелка-Плюс
16 December 2017, 08:09:00
16 December 2017, 08:33:00
Hyundi505, changed speed limit from 50 to 60.
Hyundi505, changed warning direction from 88 to 90.
Hyundi505, changed object notification distance from 500 to 300.
Hyundi505, changed object description from 'Объект добавлен с помощью программы MapcamDroid (offline)' to 'АвтоУраган-ВСМ-2'.
16 December 2017, 08:33:30
Установлен на ОХ
22 December 2017, 04:56:09
, changed object latitude from 37.807626 to 37.807846
, changed object longitude from 55.810574 to 55.810523
, changed warning direction from 90 to 88.
22 December 2017, 04:58:24
Будут подтверждения средней скорости, как на Аминьевке, поменяем тип.
11 January 2018, 08:31:12
, changed object latitude from 37.807846 to 37.807470
, changed object longitude from 55.810523 to 55.810520
, changed warning direction from 88 to 85.
, changed object notification distance from 300 to 350.
15 January 2018, 12:47:46
ловит островок
15 January 2018, 12:54:55
Есть штраф с неё?
24 January 2018, 10:57:42
АУ в эксплуатации (ниже): +1
24 January 2018, 10:58:12
03 February 2018, 14:09:51
09 March 2018, 05:48:46
31 March 2018, 18:09:16
16 April 2018, 14:11:44
09 May 2018, 06:50:13
10 May 2018, 09:36:33
14 May 2018, 07:26:54
исправно работает
исправно работает
16 June 2018, 10:37:14
24 June 2018, 16:31:54
4
Понеслась:( Меняйте тип камеры на измерение средней скорости!
25 June 2018, 06:30:26
Спасибо за фото! Если хотите, чтобы Ваш комментарий увидели и прочитали, пишите его отдельно от фотографии. Появился участок контроля средней скорости между двумя Ураганами
25 June 2018, 11:01:56
Спасибо +
27 June 2018, 06:50:18
25 June 2018, 11:13:54
, changed object longitude from 55.810520 to 55.810529
, changed object type from  Static speed camera Static speed camera to  Twin camera Twin camera.
, changed object notification distance from 350 to 300.
25 June 2018, 11:23:52
25 June 2018, 11:57:32
25 June 2018, 12:00:55
27 June 2018, 06:50:58
Ashkrmane, changed object type from  Twin camera Twin camera to  Traffic control complex Traffic control complex.
04 July 2018, 08:11:28
04 July 2018, 08:18:33
Спасибо. Сразу плюс за свежее фото. С почином.
04 July 2018, 08:27:29
Спасибо! +
11 July 2018, 15:02:51
13 July 2018, 18:45:47
28 July 2018, 10:10:14
на отрезок
на отрезок
12 August 2018, 17:10:52
26 August 2018, 19:11:56
26 August 2018, 19:13:31
04 September 2018, 07:32:08
В здравии
formula aluminum oxide
04 September 2018, 07:33:35
Отредактируйте, пожалуйста, коммент.
Ссыль рекламная прицепилась :(
12 September 2018, 05:04:40
Для мото неактуально. -1
23 September 2018, 13:44:00
26 September 2018, 16:09:06
19 October 2018, 05:10:51
19 October 2018, 05:12:24
Штрафует.
31 October 2018, 19:36:51
05 November 2018, 23:22:52
12 November 2018, 20:20:08
11 January 2019, 23:20:29
11 January 2019, 23:21:00
Штрафы. +1
11 January 2019, 23:21:04
Штрафы. +1
04 March 2019, 15:32:47
13 May 2019, 10:44:46
17 May 2019, 07:20:58
, changed warning direction from 85 to 89.
03 September 2019, 12:30:14
23 September 2019, 10:44:48
23 September 2019, 10:49:25
Немного странно. Камера уже старая, известная. Ехал как всегда, чуть ниже 80. На треке поездки через OBD2 максимальная скорость на этом участке 77.65 км/ч. Всякое может быть, но некоторой накрутки не исключаю.
16 October 2019, 20:29:29
01 November 2019, 08:41:13
25 November 2019, 08:56:54
Штраф.
12 May 2020, 12:39:33
12 May 2020, 12:39:42
14 May 2020, 05:11:53
15 May 2020, 15:23:02
Yald, changed control area.
15 May 2020, 15:24:20
Контроль средней скорости вынес в отдельный объект: idm=zOTJPydM1UA
10 April 2021, 13:00:47
зачем?
14 March 2021, 12:25:59
intruder197, changed object notification distance from 300 to 250.
18 March 2021, 05:01:24
Hyundi505, changed object notification distance from 250 to 300.
18 July 2021, 15:38:33
07 September 2021, 09:56:22
balabol.1974, changed warning direction from 89 to 90.
20 February 2022, 19:48:39
balabol.1974, changed object description from 'АвтоУраган-ВСМ-2' to 'МУЛЯЖ! АвтоУраган (рейтинг ноль)'.
20 February 2022, 19:49:12
выведена из эксплуатации -1
20 February 2022, 19:49:15
20 February 2022, 19:49:18
актуален рейтинг ноль -1
20 February 2022, 19:49:21
22 February 2022, 18:00:53
Рейтинг ноль -1
22 February 2022, 18:01:00
Рейтинг ноль -1
03 November 2022, 04:29:50
Замена на новую
03 November 2022, 04:30:23
Замена на новую +1
03 November 2022, 04:30:38
Замена на новую +1
16 November 2022, 03:17:50
balabol.1974, changed object description from 'МУЛЯЖ! АвтоУраган (рейтинг ноль)' to 'Стрелка-Плюс'.
06 May 2024, 09:55:39
поменяли камеру
06 May 2024, 09:56:03
06 May 2024, 21:55:21
25 February 2025, 07:57:18
штраф +1
25 February 2025, 07:57:22
штраф +1
25 February 2025, 08:08:42
