22 October 2026, 02:58:33
АРЕНА
Russian Federation > Республика Адыгея
25 October 2010, 08:50:19
26 October 2010, 06:50:36
Марик, changed warning direction type from All directions (360) to In a certain direction.
Марик, changed warning direction from 0 to 307.
18 May 2012, 12:27:11
Кто поможет указать или описать тип камеры? Поискать похожие можно здесь:Технические средства фиксации нарушений ПДД
18 July 2013, 16:35:42
Тип камеры не скажу, но точно стационарная фонит  очень далеко по РД, может КРИС +1
14 May 2014, 13:21:19
Стационарный комплекс "АРЕНА" +1
15 May 2014, 03:46:38
barsmur, changed object description from 'въезд в город' to 'Стационарный комплекс АРЕНА, контроль скорости 60 км/ч'.
04 June 2015, 11:15:48
висит +1
10 December 2018, 20:14:45
yuryleb, changed object latitude from 40.056474 to 40.056416
yuryleb, changed object longitude from 44.622573 to 44.622534
yuryleb, changed warning direction from 307 to 309.
30 March 2019, 20:00:27
Для мото неактуально -1
12 June 2019, 19:49:46
kenalog, changed object description from 'Стационарный комплекс АРЕНА, контроль скорости 60 км/ч' to ' АРЕНА'.
09 August 2019, 05:52:24
07 April 2020, 03:58:13
07 April 2020, 10:05:30
13 April 2020, 02:53:10
01 May 2021, 17:46:02
01 May 2021, 17:46:38
Камера на месте
07 November 2023, 14:02:22
Камеру сняли -1
07 November 2023, 14:02:29
Камеру сняли -1
26 July 2024, 11:11:47
Надо убрать, камеры больше нет.
26 July 2024, 15:20:51
26 July 2024, 15:20:56
26 July 2024, 15:22:14
Нужны минусы
26 July 2024, 15:56:06
По просьбе -1
26 July 2024, 15:56:17
По просьбе -1
27 July 2024, 11:23:43
27 July 2024, 11:23:47
27 July 2024, 11:23:49
27 July 2024, 11:24:16
27 July 2024, 11:27:01
См. выше -1
27 July 2024, 11:27:05
См. выше -1
