23 October 2026, 11:40:42
КРИС-П (тыл) [33КМ 618М]
29 July 2016, 11:33:39
29 July 2016, 11:34:40
29 July 2016, 14:30:54
+ за фото
29 July 2016, 14:29:51
Hyundi505, changed object latitude from 41.639777 to 41.639734
Hyundi505, changed object longitude from 52.769503 to 52.769507
Hyundi505, changed object type from  Static speed camera Static speed camera to  Рossible mobile police post. (focus on speed!) Рossible mobile police post. (focus on speed!).
Hyundi505, changed warning direction from 224 to 225.
29 July 2016, 14:30:35
Скорее всего, такой тип ;) а Крис на земле, похоже, лежит.
29 September 2016, 05:39:48
Да на земле лежит пара в обоих направлениях. Добавил соседнюю точку.
27 June 2017, 09:03:51
02 August 2017, 04:51:33
прохоров, changed speed limit from 40 to 50.
прохоров, changed warning end time from 24 to 22.
02 August 2017, 04:52:06
Изменил ограничение скорости по последнему фото
03 August 2017, 03:31:19
Вернул ограничение 40 по комментариям в соседней точке.
02 August 2017, 04:58:21
03 August 2017, 03:30:06
прохоров, changed speed limit from 50 to 40.
25 May 2018, 15:49:47
01 July 2020, 11:46:02
01 July 2020, 11:51:13
22 August 2020, 16:39:02
50, а не 40 -1
22 August 2020, 16:39:06
50, а не 40 -1
22 August 2020, 16:48:15
Помните, что ставя минус, Вы можете полностью вывести рабочую точку из строя и она вообще никого ни о чем не предупредит. Достаточно оставить сообщение, его прочитают и внесут коррективы в точку
22 August 2020, 17:10:36
ОК
22 August 2020, 16:44:16
Необоснованное понижение рейтинга +1
22 August 2020, 16:44:19
22 August 2020, 16:47:17
Timon34, changed speed limit from 40 to 50.
02 April 2021, 18:40:28
vaz2015, changed object description from 'КРИС-П' to 'КРИС-П [33КМ 800М'.
02 April 2021, 18:40:54
06 February 2023, 06:45:37
Timon34, changed object latitude from 41.639734 to 41.639948
Timon34, changed object longitude from 52.769507 to 52.771373
Timon34, changed object type from  Рossible mobile police post. (focus on speed!) Рossible mobile police post. (focus on speed!) to  Integrated camera Integrated camera.
Timon34, changed warning direction from 225 to 205.
Timon34, changed control direction from Counter direction to In the back.
Timon34, changed object view angle from 15 to 60.
Timon34, changed object description from 'КРИС-П [33КМ 800М' to 'КРИС-П [33КМ 800М]'.
06 February 2023, 06:46:09
Timon34, changed object description from 'КРИС-П [33КМ 800М]' to 'КРИС-П (тыл) [33КМ 618М]'.
24 September 2026, 19:28:51
Точка устарела ,инфо в парной . -1
24 September 2026, 19:28:53
24 September 2026, 19:28:56
25 September 2026, 03:11:22
25 September 2026, 03:11:25
25 September 2026, 03:11:27
