22 October 2026, 02:13:26
09 February 2021, 03:12:49
14 February 2021, 16:24:01
oloolo2013, changed object type from  Bad road ahead Bad road ahead to  Speed Bump Speed Bump.
oloolo2013, changed speed limit from 0 to 20.
oloolo2013, changed object notification distance from 500 to 400.
oloolo2013, confirmed object added via Mapcam.info program
02 July 2021, 03:47:23
Timon34, changed object notification distance from 400 to 180.
Timon34, changed object description from 'Объект добавлен 2021-02-09 03:12:46 с помощью MapcamDroid' to 'Лежачий полицейский'.
04 November 2023, 12:26:06
Лежачих полицейских нет. Просьба к автору удалить точки. Спасибо.
10 November 2023, 22:10:54
На удаление -1
10 November 2023, 22:10:57
На удаление -1
10 November 2023, 22:10:58
На удаление -1
11 November 2023, 02:38:39
См.выше. Удалил -1
11 November 2023, 02:38:45
См.выше. Удалил -1
11 November 2023, 02:38:48
См.выше. Удалил -1
11 November 2023, 18:48:25
kenalog, changed object notification distance from 180 to 100.
kenalog, changed object view angle from 15 to 10.
