22 October 2026, 02:13:27
ЛИДЕР-С
15 February 2015, 17:41:22
15 February 2015, 17:44:33
, changed object description from 'Тренога' to 'КРИС-П 60км/ч'.
26 February 2015, 11:12:56
Подтверждаю! 26 февраля стоял. +1
22 March 2015, 13:14:16
КРИС-П и пастух
КРИС-П и пастух
04 June 2015, 07:22:28
Крис-П. 60км/ч
Крис-П. 60км/ч
04 June 2015, 07:25:40
Трудится
Трудится
05 June 2015, 07:33:16
silandser, changed object latitude from 39.272706 to 39.272602
silandser, changed object longitude from 51.674668 to 51.674171
05 June 2015, 07:33:57
Поставил по GPS (MCD) http://mapcam.info/speedcam/point.php?idx=755063
24 August 2015, 05:53:18
24.08.2015 стоят два КРИСа
24 August 2015, 16:48:01
Два КРИСа
Два КРИСа
04 November 2015, 11:18:26
silandser, changed object type from  Portable Camera (trap) Portable Camera (trap) to  Рossible mobile police post. (focus on speed!) Рossible mobile police post. (focus on speed!).
11 January 2016, 11:55:59
КРИС-П
КРИС-П
11 January 2016, 11:56:34
10.01.2016 стояли два КРИСа
21 January 2016, 19:54:13
23 January 2016, 20:00:05
06 March 2016, 19:37:23
30 March 2016, 14:37:27
13 May 2016, 09:53:38
Фоторепортаж
Фоторепортаж
14 May 2016, 19:47:45
14 June 2017, 04:39:07
На столбе повесили Стрелку. В сторону Репного.
15 June 2017, 05:52:56
15 June 2017, 06:29:52
Похоже стрелка
15 June 2017, 06:31:30
Нет. Это МультаРадар скорее всего
15 June 2017, 06:43:20
Он самый,стрелки на столб не вешают таким образом,по крайней мере не видел никогда
15 June 2017, 08:05:20
Теперь там статическая камера Фотон. Точку к удалению.
15 June 2017, 08:12:16
Или не удалять, а поставить в пару к соседней точке
22 June 2017, 20:08:06
Карл! Мультик здесь!!!
24 June 2017, 07:42:30
silandser, changed object latitude from 39.272602 to 39.272796
silandser, changed object longitude from 51.674171 to 51.675193
silandser, changed object type from  Рossible mobile police post. (focus on speed!) Рossible mobile police post. (focus on speed!) to  Static speed camera Static speed camera.
silandser, changed object description from 'КРИС-П 60км/ч' to 'MultaRadar SD580'.
24 June 2017, 07:44:33
Поставил по GPS. Для контроля в спину соседняя точка трансформирована. См.общую карту
24 June 2017, 10:09:13
21 January 2018, 12:34:22
21 January 2018, 12:34:59
20 March 2018, 10:32:35
Радар убрали недели две как.
20 March 2018, 13:18:22
silandser, changed object type from  Static speed camera Static speed camera to  Other danger Other danger.
silandser, changed warning direction from 8 to 94.
silandser, changed object description from 'MultaRadar SD580' to 'До появления треног'.
20 March 2018, 13:18:48
Возможно появление треног. Подождем и понаблюдаем.
19 September 2018, 14:33:40
silandser, changed object latitude from 39.272796 to 39.272900
silandser, changed object longitude from 51.675193 to 51.675700
silandser, changed object type from  Other danger Other danger to  Static speed camera Static speed camera.
silandser, changed warning direction from 94 to 8.
silandser, changed object notification distance from 100 to 500.
silandser, changed object view angle from 10 to 25.
silandser, changed object description from 'До появления треног' to 'MultaRadar SD580'.
19 September 2018, 14:34:09
19 September 2018, 14:35:32
silandser, changed object latitude from 39.272900 to 39.272906
silandser, changed object longitude from 51.675700 to 51.675487
19 September 2018, 14:35:59
Замер координат через приложение https://mapcam.info/speedcam/point.php?idx=1077928
19 September 2018, 14:53:57
Опередил. Тоже вчера его увидел.
29 January 2019, 16:40:17
мото не пробивает в лоб -1
29 January 2019, 17:11:15
29 January 2019, 17:34:58
10 February 2021, 19:11:11
silandser, changed object description from 'MultaRadar SD580' to 'ЛИДЕР-С'.
10 February 2021, 19:11:18
10 October 2023, 16:52:17
Камера демонтирована вместе со столбом. Свою парную точку удалил -1
10 October 2023, 16:52:20
10 October 2023, 16:52:23
26 October 2023, 17:03:59
26 October 2023, 17:04:03
26 October 2023, 17:31:56
26 October 2023, 17:32:02
26 October 2023, 19:13:44
см выше, удалил -1
26 October 2023, 19:13:47
см выше, удалил -1
26 October 2023, 19:13:59
kenalog, changed object notification distance from 500 to 100.
kenalog, changed object view angle from 25 to 10.
