05 November 2026, 07:27:38
For the past 24 hours: 73 objects added, 87 objects edited, 18 objects removed.
Ящик под камеру [94км 400м] (в спину)
18 June 2019, 12:50:27
18 June 2019, 13:06:04
Timon34, changed object notification distance from 888 to 500.
Timon34, changed object view angle from 28 to 25.
20 June 2019, 21:59:04
20 June 2019, 22:02:45
Из Вологды.
20 June 2019, 22:01:38
, changed object description from 'Статическая камера, измеряющая скорость' to 'КРИС-П [94км 400м]'.
20 June 2019, 22:38:40
Есть штраф. +1
20 June 2019, 22:38:44
Есть штраф. +1
20 June 2019, 22:38:48
Есть штраф. +1
21 June 2019, 03:22:07
05 April 2020, 01:56:39
semaa1, changed control area.
semaa1, changed object type from  Static speed camera Static speed camera to   .
05 April 2020, 01:56:52
semaa1, changed object description from 'КРИС-П [94км 400м]' to 'КРИС-П [94км 400м] (в спину)'.
20 July 2020, 15:30:50
30 September 2021, 23:14:23
В Вологду:[img]data:image/jpeg;base64,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 Tl5ufo6erx8vP09fb3 Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3 Pn6/9oADAMBAAIRAxEAPwDnf CeP/BST9on9pH4Map4h8VfGzx/JcWWoXFqn2IWUZcJHbMo2mDH/LR/rxX1H8Pviz8ZPE8TQn45fEq7vLhka3xPZxqoILMhH2bO4KM18Ef8EWba5m/ZJ13a1vHBceLpIY2dGL7xa2pfbgHsy8Yr768O6l
30 September 2021, 23:15:30
[img]data:image/jpeg;base64,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 Tl5ufo6erx8vP09fb3 Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3 Pn6/9oADAMBAAIRAxEAPwDnf CeP/BST9on9pH4Map4h8VfGzx/JcWWoXFqn2IWUZcJHbMo2mDH/LR/rxX1H8Pviz8ZPE8TQn45fEq7vLhka3xPZxqoILMhH2bO4KM18Ef8EWba5m/ZJ13a1vHBceLpIY2dGL7xa2pfbgHsy8Yr768O6lp1l8DfHNsU
01 October 2021, 16:02:26
Меню под картинкой слева "добавит фото". Не более 1 Мb, jpg.
23 December 2024, 19:50:21
, changed object latitude from 38.871061 to 38.871000
, changed object longitude from 59.842794 to 59.842775
, changed object description from 'КРИС-П [94км 400м] (в спину)' to 'Ящик под камеру [94км 400м] (в спину)'.
07 January 2025, 08:11:30
Убрали, прошу помощи в удалении -1
07 January 2025, 08:11:33
07 January 2025, 08:11:35
07 January 2025, 12:56:30
 См. выше -1
07 January 2025, 12:56:33
 См. выше -1
07 January 2025, 12:56:35
 См. выше -1
07 January 2025, 16:39:58
См выше.Удалил -1
07 January 2025, 16:40:00
См выше.Удалил -1
07 January 2025, 16:40:02
См выше.Удалил -1
07 January 2025, 16:40:13
