13 November 2026, 12:22:47
For the past 24 hours: 59 objects added, 89 objects edited, 30 objects removed.
СКАТ-П [59км 550м]
04 August 2019, 11:33:12
04 August 2019, 11:37:18
maykl3011, changed object latitude from 36.761246 to 36.762346
maykl3011, changed object longitude from 55.857021 to 55.856826
maykl3011, changed object type from   to  Рossible mobile police post. (focus on speed!) Рossible mobile police post. (focus on speed!).
maykl3011, changed speed limit from 0 to 90.
maykl3011, changed warning direction type from Two directions to In a certain direction.
maykl3011, changed warning direction from 110 to 109.
maykl3011, changed object notification distance from 500 to 600.
maykl3011, changed object description from 'Объект добавлен с помощью программы MapcamDroid (offline)' to 'СКАТ-П'.
maykl3011, confirmed object added via Mapcam.info program
maykl3011, changed warning start time from 0 to 7.
maykl3011, changed warning end time from 24 to 23.
maykl3011, changed camera model.
04 August 2019, 11:38:13
Сегодня обнаружено новое место дислокации.
04 August 2019, 13:05:06
Все верно и сходится. Напротив тоже засада.
04 August 2019, 13:57:31
Обратно ехал не видел, конечно мог пропустить.
04 August 2019, 13:06:34
11 August 2019, 18:16:53
11 August 2019, 18:18:50
Есть такая камера... только что штраф получил :(
11 August 2019, 18:23:09
спасибо, плюс
11 August 2019, 18:22:13
Timon34, changed object description from 'СКАТ-П' to 'СКАТ-П [59км 550м]'.
11 August 2019, 18:22:28
Подтверждено +1
11 August 2019, 18:22:31
Подтверждено +1
11 August 2019, 18:22:33
Подтверждено +1
19 August 2019, 05:32:45
работают
19 August 2019, 05:33:07
Hyundi505, changed warning start time from 7 to 6.
19 August 2019, 06:13:58
maykl3011, changed warning start time from 6 to 0.
maykl3011, changed warning end time from 23 to 24.
19 August 2019, 06:16:00
Напротив ночью стоят, т.к. освещение позволяет, думаю здесь тоже. Забыл здесь поправить.
22 August 2019, 14:35:28
22 August 2019, 14:37:11
Спряталась за столбом со знаком.
03 September 2019, 05:35:40
работала
07 September 2019, 19:11:14
12 October 2019, 18:48:02
работали
11 November 2019, 05:17:10
на той неделе раб.
11 November 2019, 12:47:34
maykl3011, changed object latitude from 36.762346 to 36.761501
maykl3011, changed object longitude from 55.856826 to 55.856990
25 November 2019, 05:31:30
не было
25 November 2019, 06:35:29
Странно, стоят чуть ли не круглосуточно. Вторник и четверг на месте были.
25 November 2019, 06:36:41
Я сам удивился. Вчера в других точках (скатных) тоже не работали.
18 January 2020, 18:21:27
вечером вчера не было после 20, скорее всего после нг так и не приехали пока
19 January 2020, 07:34:53
Декабрь- январь не появляются, но удалять рано, я бы и февраль подержал.
19 January 2020, 08:00:17
Я про удаление не говорил)), у нас есть любители, которые через "неделю" отсутствия сразу удаляют. Думаю, что пока не все машины переоборудовали под скат, позже расставятся по точкам.
27 January 2020, 05:54:51
maykl3011, switched object to test mode
27 January 2020, 09:40:51
не было на неделе?
27 January 2020, 18:53:07
И сегодня пусто ;)
18 April 2020, 17:52:16
идет ремонт. ограничение 60. Просьба из теста вывести
18 April 2020, 17:52:36
Hyundi505, changed speed limit from 110 to 60.
Hyundi505, changed speed limit from 90 to 60.
Hyundi505, changed object notification distance from 600 to 450.
18 April 2020, 19:55:21
maykl3011, turned off test mode
21 April 2020, 17:20:31
Сегодня стоит машина со скатом и знак временное ограничение с табличкой фиксации висит.
21 April 2020, 17:21:34
maykl3011, changed object notification distance from 450 to 500.
21 April 2020, 17:23:59
Тренога теперь не актуальна, т.к. стали ставить мобильный комплекс.
21 April 2020, 17:37:21
Точно, надо было мне снести ттс. Спасибо
26 April 2020, 09:24:41
работает
28 April 2020, 05:35:48
28 April 2020, 05:36:05
Работает, на 60 км/ч. Там ремонтные работы и временный знак 60.
01 May 2020, 06:57:57
01 May 2020, 06:58:19
01 May 2020, 09:56:59
01 May 2020, 09:57:04
06 May 2020, 05:50:52
Ashkrmane, changed object notification distance from 500 to 800.
06 May 2020, 05:52:52
Парни, мало очень 500 метров. Даже при условии дождя и незаоблачной скорости.
06 May 2020, 08:40:40
Когда не было ремонта и 600 метров за глаза хватало.
06 May 2020, 08:46:02
Но больше - не меньше, протестируем, пока ремонт, место не приятное.
06 May 2020, 08:49:50
Штрафов тьма будет в первое время. Мимо меня много машин пронеслось.
06 May 2020, 08:59:46
Это и понятно, левый ряд без сужения и трудно соблюдать ограничение 60 20, как будто остановился полностью.
06 May 2020, 09:22:30
В доп инфу скорость 60 упомянуть.
06 May 2020, 05:55:45
Для мото неактульно -1
06 May 2020, 08:39:37
Мото 0. -1
06 May 2020, 08:40:36
06 May 2020, 08:42:37
Поверка до 29.01.2022
06 May 2020, 13:19:46
07 May 2020, 14:55:51
12.09.3 - Превышение скорости движения ТС от 40 до 60 км/ч 29 апреля в 16:13 по адресу: МОСКОВСКАЯ ОБЛ. 59 КМ   550 М, А/Д М-9 <<БАЛТИЯ>> Оплачен Штраф 1000 Номер постановления 1881015020050... Дата постановления 06.05.2020
14 May 2020, 22:22:24
14 May 2020, 22:22:31
24 May 2020, 10:41:57
25 May 2020, 07:30:01
25 May 2020, 07:30:15
31 May 2020, 11:16:45
06 June 2020, 11:30:32
08 June 2020, 11:04:15
на днях пару раз не видел
29 June 2020, 17:21:31
Снова появилась https://mapcam.info/forum/index.php?topic=5769.msg88069#msg88069 Ждем когда автор выложит скан в точку
06 July 2020, 18:32:53
ага, видел в середине и конце июня
30 June 2020, 12:49:54
30 June 2020, 12:50:35
Прилетело с этого участка, превышение 60 км. Чтоб его там закопали )))
01 July 2020, 07:40:51
Печально. Кормушка ещё та, после прямой с ограничением 110 не меняя полосы попадаешь на участок 60.
02 July 2020, 08:42:21
Ashkrmane, changed object notification distance from 800 to 650.
02 July 2020, 08:43:42
Уменьшил на 150 метров. Проезжал несколько раз - рано срабатывает :)
02 July 2020, 08:44:42
Да и многие засаду уже знают, камера стала пробки собирать.
13 July 2020, 09:18:12
15 July 2020, 09:19:03
01 September 2020, 10:57:38
03 September 2020, 17:52:59
14 September 2020, 05:48:22
Беспредел какой-то... Ремонта там уже давно нет. Он был - устанавливали шумозащитные экраны. Все давно уже закончено. Сейчас остается только отгороженная гранта. Рядом насыпали для вида гору щебня... Все. Ситуация такая же, как и тут.
15 September 2020, 06:15:37
01 October 2020, 20:00:21
Сегодня не было на месте, ограждения сняли, но знаки пока не убрали.
02 October 2020, 04:50:06
Спасибо
05 October 2020, 11:10:54
Засада больше тут не планируется. Думаю можно в тест или на удаление.
15 October 2020, 05:30:58
Встать им здесь теперь негде, шумозащитные щиты смонтировали, удаляю. Только вопрос, где теперь появятся?
05 October 2020, 11:28:16
Раньше, до ремонта тут всегда была засада на 110 км/ч... Предлагаю пока сделать рейтинг 0.
05 October 2020, 18:42:56
В тест пока. Сегодня пусто, ограничения сняли.
05 October 2020, 18:43:19
maykl3011, changed speed limit from 60 to 110.
maykl3011, changed speed limit from 60 to 90.
05 October 2020, 18:43:32
05 October 2020, 18:47:37
